964 Turbo Forum 1989-1994
Triple Bypass - Sounds Serious!
Old 11-28-2006, 12:48 PM
  #31
911addict
911addict's Avatar
pzull,
if you cruise on closed throttle, do you pop?
I do, so is that a problem or is it normal to be lean on lift off? (I love the popping, it sounds MEAN!)
My acceleration and general running is all perfect.
Old 11-28-2006, 07:22 PM
  #32
911 2
911 2's Avatar
myn only pops on lift off does that mean its still running lean when driving
Old 11-28-2006, 08:26 PM
  #33
nathanUK '81 930 G50
nathanUK '81 930 G50's Avatar
I believe most EFI cars including my 3.2 carrera shut off fuel when you lift off the gas above certain RPM. I am guessing the CIS can't do this so I suppose it just leans out the mixture to save fuel. As no power is being produced it should be safe.
Correct me if I am wrong guys.
Old 11-28-2006, 09:20 PM
  #34
JBL930
Not Forgotten
JBL930's Avatar
In my understanding the only time a CIS 930/965 is in DANGER from running lean is at WOT, if your car is below 400bhp then the standard (euro) CIS can cope without issue. Above this then the various; fuel enrichment, adjustable WUR, digital WUR, seventh injector, fuel head mod etc are used to get more fuel. With your foot off the accelerator there is little if any air or fuel getting into your cylinders, and also no load on the engine, therefore no knock, no pre-detonation, no problem
Old 11-28-2006, 09:57 PM
  #35
pzull
pzull's Avatar
Originally Posted by 911addict
pzull,
No pops whatsoever under all scenarios. Tuner did it that way as I said I wanted it that way. He said he could tune in loud or soft pops or flames if I wanted to but he said it is more a gimmick rather than any real world benefits.
However if there is for any reason an overboost situation I would get flames as he tuned in fuel dump and ignition retardation to protect the engine. But it not a situation I am looking forward to
Old 12-04-2006, 09:13 PM
  #36
911addict
911addict's Avatar
Talking of POPS.....
I went on a 2 hour run to the PCGB HQ on Sunday and went with another couple of 3.3 turbos :-)
On the way back, as we drove through some villages the roads were very narrow and the sound of my exhaust echoed. It really burbles and pops (& bangs) on lift off. Pedestrians all looked. The 965 behind me said it sounds amazing. He has a G-pipe and now wants the double (cat bypass)....
When we got on the motorway, he heard my Wastegate bypass scream and he wants one of those too!
Quick Reply: Triple Bypass - Sounds Serious!
