damaged speedline 3.6
I called this morning(afternoon in Germany) the phone number above did not work because the country code was incorrect, but I did reach them by calling 011 49 6150 7026 and spoke with Thomas Schneider who is my contact for the wrench to remove the bolts and nuts hold rim halves together. They supply many wheel manufacturers and will make a rim half if they can not get it.
His email address is schneider@titanium-touch.com
1 Post
I just noticed that the Speedline nuts and bolts are available from FVD (at www.fvd-web.com) for $4 each. (see FVD 362 965 005 and FVD 362 965 006). They also carry other pieces of the rims. Hope this (still) helps.
You better believe it does. Thanks for the post. I have been all over the FVD site and never once thought to look for this stuff. If the outer rings say Speedline for Porsche on them I think I might buy a set of spares just in case something happens.
so where do you stand on the set of wheels? progress to report? I am refinishing a set of Oz techart TT wheels (damaged of course) had to buy 4 outer rims halves. Expensive, but should make the wheels perfect. Decided to make rear wheels wider so I ordered .75" wider outer half 3.75" making my rear wheel 11.60 wide. I can not tell you how many hours I spend stripping clear coat then sanding centers to get to a higher polish level than before plus I am still going to send out for final polish and clear coat. I am also looking for 1 Speedline 3.6 18" rear wheel if anyone knows where one is. thanks! --Jim
