X88 dyno results
#31
Originally Posted by Jean
Ever wonder why we always hear about Porsche cars being understated by the factory following a chassis dyno session usually? Well they are not, they are just measured right at the factory, it is the chassis dyno being overstated.
Also, any dyno not SAE or DIN corrected is just worhtless other than for tuning purposes. The same applies to engine dynos, they need to be corrected to a standard.
Do a 60-130mph run with a GPS based logger and show the real torque and HP your car is producing
#32
Originally Posted by tjn
mr flachbau, i have always been told that the dyno (depending upon mfgr.) always reads the "wheel HP" at 23-25% lower than ground hp. watcha think? tjn/vk
Maybe this is what you mean?
#33
This is from an article from German Motorcars website which I think reinforces some of the points being made in this thread:
'A Dynamometer can only measure actual power at the output location. Actual power produced AND delivered by an engine will be highest if measured at the crankshaft, lower at the transmission output shaft and even lower, but more meaningful, still, at the rear wheels. The power that you use is the power at the rear wheels. Some Dynamometer companies add to measured rear wheel power readings a factor that is based on ESTIMATED rear wheel power losses (under what power conditions? 3.0 ltr.? 5.0 ltr.? Under coasting conditions? with a 185/70/15 radial tire? a 335/35/18 radial tire? New heavy radial tire vs. worn old, light, racing tire? Who knows?) In short, there is NO meaningful "average" tire to get a correct rear tire power transmission loss measurement for all cars - so obviously, unless they actually measure the power lost in the rear tires, under driven load conditions, NO dyno company should BE ADDING incorrect power figures into the measured power. It's simply wrong. The fact that they add varying amounts of power to the actual, "true" amount of power delivered and measured to the surface of the drive roller creates a situation that makes it an onerous task to compare power figures from different brands of dynamometer systems. '
#34
RIP
RIP
Here we go again....
My comment about under reading was tounge in cheek.
My understanding is that the dyno that 9m use, approx. fly wheel hp by coast down calculations, and hence will adjust for different set ups.
I also totally agree with Jean that turbo cars are more prone to heat-hp issues than NA cars and the 60-130 test is a good one. However dyno's have there place...
#36
I thought my post would generate some discussion! I am out of my depth to comment but its interesting watching things unfold.i was happy that my engine seems pretty healthy and have something to compare when i do a cat bypass or other mod.9m did say that this was the best way to use the figures.Out of interest we did another run after disconnectig the lambda sensor and hp went down by 5 , so probably didnt make any difference at this stage.
I have now had info from Ruf that an Eks electronic clutch was fitted ( now removed ) for a short while.They didnt have a record of any other mods but couldnt say for sure without seeing the car.
#37
Originally Posted by JBL930
I would love to do a 60mph-130mph run, anyone fancy lending me their AX22 for a day?
