Recommendations for Steering Wheel?
My car is seeing a lot of track time so perhaps it is time to find a more comfortable steering wheel. The obvious problem that makes this less than a straight replacement is the airbag and associated OBD electronics.
Has someone done the replacement to a non-airbag wheel?
Is there a link to a step-by-step process?
What type of adapter do I need and who sells them?
What kind of wheel do you have?
Thanks!
Thanks!
Originally Posted by Megatron-UK
Can airbag wheels be retrofitted onto cars without the airbag, or does the car have to have been equipped with one originally?
Jeffrey,
The wheel replacement is an easy one and there are a few simple rules you need to follow. Joey Baggadonuts has a great write up on the 964 list that outlines all the parts you need. I did the job myself and fitted a Momo Monte Carlo, very nice wheel.
I recall I needed:
Momo wheel
Momo hub adapter 7004
Porsche horn contact 964.652.104.00
2.8ohm resisitor for airbag fooling
The following link outlines the procedure, beware of regulations on airbag removal in certain countries.
https://rennlist.com/forums/964-forum/122479-okay-you-asked-for-it-momo-wheel-installation-made-easy.html
Use this link to understand the differnce with the 2.8 ohm trick and OEM airnag tester fitment
https://rennlist.com/forums/showthre...ghlight=airbag
Good luck, it aint a hard one.
I recall I needed:
Momo wheel
It looks similar. The FVD I installed is 12.5" diameter, I believe the AJ USA one is about 13.25". Also, I think the FVD is a little thicker. I considered the AJ USA one, but went with the FVD wheel. The FVD wheel also has a nice grip at the 3 and 9 o'clock.
Oooh..I like the FVD wheel. Did you do the installation yourselves? I don't mond keeping the air bag as long as I can get a smaller, thicker wheel.
Thanks for all the information!
Yes it does require a hub adapter. FVD have two different versions of the adapter (leather and standard). Difference of about $25 between the two. Since the wheel I used is leather, I used the leather version. The parts are: Steering wheel - FVD 347 010, Adapter - FVD 347 170 1801
Hope that helps.
Hope that helps.
JBH - The only thing to consider with the 340mm FVD/Atiwe wheel is that it will block your tach. This may not bother you, but food for thought.
Porshah - I saw your car at Paterek once. That color is great looking. Will you be at the Long Valley BBQ?
Craig
Craig
