painted tail lights results
Registered User
Heres results of my painting my tail lights after all the good advice on here.
1st pic is old lenses followed by painted ones.
JERRY
JERRY
Registered User
Hi wilkins, I first wet sanded lenses with 600 grit sand paper. Then did 3 coats of this...http://www.hobbylinc.com/htm/tes/tes1605.htm. Let dry for about 24 hours then did 6 coats of Krylon UV resistant clear coat. Let dry again for about 24 hours. But now i would recommend 48 hours because a couple of times my finger prints were imprinted in the clear coat which i had to sand out. Then i wet sanded with 2000 grit sandpaper till it was really smooth. Then i buffed with Zymol cleaner wax. Followed by buffed with mcquires wax.
JERRY
JERRY
Registered User
Oh yea the lights are fine maybe not quite as bright but not a safety issue. The only thing is the turn signals and reverse lights have a pinkish hue. But no biggy to me.
JERRY
JERRY
Very nice but i still can't figure out what you did with the lights
any way on a different note,i see you have an after market headers and a stock muffler with B&B tail pipes,is that correct ?
Looks like a full B&B setup to me. The oval tips are welded onto the end of the B&B exhaust. Plus Porsche would never build a muffler that would hang down below the rear fascia. I am shocked he was able to get the B&B tips to line up as well as they do.
I just replaced my rear lenses with OE parts. Wholesale it ran me almost $900.00 plus Porsche only builds them as an assembly with wire harness and bulbs. So this is not a bad way to go.
Craig
Craig
Craig
