Updated 3.6 Turbo Pics
Originally Posted by VinnyC
Looks Awesome! You keep your cars in the most amazing condition!! Your RSA was the cleanest I had ever seen, now your Turbo is looking top notch! impressive!!
____________________
1994 911 3.6 Turbo
1993 911 RSA sold and missed
Vinny,
I see the 928 is gone and replaced with a 73 RS clone. No luck with the RSA?
I saw the white 964 T 2 weeks ago. Current owner lives up here. Did some nice work great sounding exhaust added, along with RH wheels and lowered. Car looks and sounds geat.
Beautful car, new definition of insanity trying to keep it that spotless and at the same time drive it!
I lowered mine with the H&R coilovers and HD Bilstiens. They work great and enhance the driving pleasure. I changed the qir pressure the other day to 44 rear and 36 front, wow i never realized how much difference it makes in how the car drives.
www.perfectpowerinc.com (Illinois) sells lowering collars that will work with stock Boges. Supposedly can lower the suspension 3 inches but the shocks would have to be shortened or replaced to go that low. I like my stock suspension and the car handles great , but I plan to try the lowering collars with new shocks. Maverick, your Guards Red is really stunning. My next toy will be a guards red or black 964 Turbo and it will be the "last toy"
Registered User
Hey maverick, since were on the topic of shocks.....i would like to replace mine but i want a shock that has the same settings as the stock shocks and springs do you know or can you recommend a set???? How much would they be???
Thank you
JERRY
Thank you
JERRY
Jerry,
Not sure about setting to original specs but I am sure somebody on here does. The struts i used are Bilstiens pt# VE 5277 HO and VE 5278 HO.($285 ea) The shocks were also Bilstiens pt# B461547.($180 ea) The H &R spring set was $350.
Thanks Elliott. I finally got a chance to actually DRIVE the car this week. I took it in for an oil change as well as diff fluid change. Everything checked out great and it ran fantastic. I also had the fabspeed bypass pipe installed. Wow, what a difference and wow that boost is intoxicating!! Very different from my RSA and Carrera. Very pleased!
_______________
1994 911 3.6 Turbo
1986 Carrera gone
_______________
1994 911 3.6 Turbo
1986 Carrera gone
