what are the advatages of a tial wastegate
need to adjust the valves very soon and as the wastegate has to come off i thought id replace it with a tial item in doing so what benefits are there and do i just look for a 46mm tial wastegate is it just bolted straight on
2. More accurate (springs are precision made and heat resistant so they actually produce the boost rate they are made to produce - as compared to stock Porsche springs which may vary by +/- .05 bar).
3. Zero overboost (holds the actual boost rate of installed spring(s) - see #2 above).
4. More spring choices (for 1.0 bar Tial requires the use of a .8 bar-large green and .2 bar spring-small yellow - I run this setup).
5. Agreed, it is a piece of art and there are 5 color choices.
Yes 46mm and make sure you get the narrow body version for the 1975-1994 911 Turbo and if running 1 bar get the highpressure model.
Check out this diagram for installation - it is a direct bolt on application.
http://www.tialsport.com/documents/w..._wginstall.pdf
Originally Posted by Turbohead
Flachbau,
Do you know?
I have a blue spring for My tial ...what is the spring boost rating for this one.
Elliot
Do you know?
Elliot
Large blue 0.9 bar
You probably have the large blue
Check this link... http://www.tialsport.com/documents/w3_tial_46_sp.pdf
The factory has worked perfectly for me, 60k miles on 1.2 bar, 387/423 to the wheels.
I have the Tial 46mm on my 928, works great, but pricy. 38mm is more than enough for our cars & stock CIS. Get a 44 if you're worried about boost creep, those are sized for 700+hp engines.
the one i have seen is a sr20 rb26 s13 tial wastegate dnt know if this will fit the 1991 turbo any ideas heres a few pics
![](http://www.madpsi.net/Projects/MR2%20(SW20)/Madpsi%20-%20Pouyas%20MR2%20-%20TiAL%20external%20wastegate.jpg)
See how the housing has little "nubs" for the bolts. That's what a real Tial 46mm looks like. I would stay away from those ebay ones, as theres no telling what kind of quality they are. Worst case is a blown engine if the wastegate siezes shut and you overboost.
What about going to 50mm? Would that cause issue?
Thanks.
RT
