964 Turbo Forum 1989-1994
View Poll Results: What Brand?
Mobil 1
40
81.63%
Motul
2
4.08%
Redline
0
0%
Other
7
14.29%
Voters: 49. You may not vote on this poll
What oil r u using?
Old 07-07-2005, 01:05 PM
  #31
Kevin
Kevin's Avatar
eyue, run the Castrol, however is it a synthetic blend.. All turbocharged engines should run synthetic!! Don't use the 0-40w
Old 07-07-2005, 01:49 PM
  #32
cobalt
cobalt's Avatar
Received 2,170 Likes on 1,299 Posts
What is wrong with the 0W-40? I use the 15W-50 but Porsche is useing the 0W-40 in the Cayenne Turbo. Just curious why it is good for the CT and not the turbo?
Old 07-07-2005, 02:12 PM
  #33
Kevin
Kevin's Avatar
Look the 996, the 996TT and all other newer watercooled Porsche engine are running vario-cam.. The oil is used like a hydrauilic pump, with servo to rotate the cams to ECU supplied timing values. On the 996 GT3, GT2 and 996TT you have 2 additional oil pumps that are driven off the cam to provide additional flow and pressure for the vario-cam.. It is designed to run on 0 and 5W oil. The air-cooled engines need viscosity and the 0 and 5W oils are to thin.. Accelerated wear to piston skirts, wrist pins and liners can occur.
Old 07-07-2005, 02:23 PM
  #34
cobalt
cobalt's Avatar
Kevin,
Something new I learned today.
Thanks for the education.
Old 07-07-2005, 03:09 PM
  #35
eyue
eyue's Avatar
Kevin, glad that I have made the right choice of using Castrol ...................
Old 07-07-2005, 06:38 PM
  #36
Brian W.
Brian W.'s Avatar
Mobil1 15w-50
Quick Reply: What oil r u using?
