Source for tach signal
Hi
I need the tach signal for a data logging unit.
I heard you are supposed to find it under the drivers seat.
Does anyone know where to find it ?
For future reference:
I found the tach source under the drivers seat, it's inside a contact with 6 wires, this contact is to the left of the ECU. The wire is black/green.
What RPM input did you put it in?
JM
Originally Posted by jrotsaert
Is your data logger a Dl90 or Dl1?
JM
JM
Logging
- boost
- EGT (soon)
- RPM
- AFR
Fantastic unit, my AFR is just where I want it.
When I got the AFR where I wanted it the clutch started to slip, a clear indication I got more hp
It's a unit from www.zeitronix.com
Logging
- boost
- EGT (soon)
- RPM
- AFR
When I got the AFR where I wanted it the clutch started to slip, a clear indication I got more hp![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Logging
- boost
- EGT (soon)
- RPM
- AFR
TIA
JM
Not sure I understand. I want a voltage signal that shows rpm for my DL90 in a 964 cup (old model) and though I have the list of all connections, I'm worried that the signal will be more than 5V which would fry my DL 90.
Any help would be GREATLY appreciated
THX
JM
THX
JM
