Lexan windows?
Can anyone tell me the benefits of lexan windows over stock? Any disadvantages? Does water leak in? Who sells good quality lexan windows and any of you guys using it?
Disadvantages: It scratches very easily compared to glass.
It's really for all out race cars.
Pesky,
Thanks. Who can I get good quality ones from?
And I'd even known about its softness and had tried my best avoid scratching it, which is also a lot of extra work (can't clean it vigorously, for example).
Unless you really need to save that weight, I'd recommend against lexan.
I've got a glass windshield in my current race car, and plan to keep it that way.
Good luck!
I would definitively keep the glass windshield but for side windows or for the rear window why not ? Especialy the rear window is a good place to save weight as it's on the rear wheels, relatively high up and we don't see much through it anyway.
Your alternative is to buy light weight RS side window panels in glass.
Another reason I wouldn't do anything in lexan is that PCA club racing rules in the stock classes prohibit it. Only legal for the windshield, which I wouldn't do either. May not be a problem for you, but your future buyer might find lexan windows (that have to be replaced) a disincentive.
Just my $0.02 worth.
Sammer - Sorry it took so long to answer. You can check this link and see if they sell the RS windows http://www.fvd.de/ they should have it on their catalogue (they have a lot of stuff there). Otherwise a Porsche center should be able to get them as well.
Yes the plastic side windows will be scratched as well but it will not be as bad as the windshield and it's not as important
Sameer,
The thin RS glass will be expensive, I do not think you can find the real thing other than at Porsche. Both the RS and the GT2 had them, the GT3 RS has them too.
As far as the lexan windows, I have put Lexan in replacement to the rear and side rear windows. The fit is perfect, just took minor work, with the new design frames I bought from Getty for a flush mount. I am sure MaShaw sells the same as well and they are Rennlist sponsors, TRG as well.
They will scratch easily but they are not expensive to replace, shipping is very inexpensive as well and there are products out there that help longevity a little, same as the ones I used to use for the motorcycle helmets shields. I would expect them to give me 1-2 years life.
If you are in a country where it rains a lot, you can always put some special silicon between the plastic frames and the body to make it completely water proof. They usually do not leak water anyway.
