Why am I smoking?
Watch the video and please offer suggestions as to why I'm smoking.
Tubbo Smoking
(it is a little hard to see in this video because I shrunk it down for the web, so you may have to kind of pan back/forth to see the puffs - thanks)
Tubbo Smoking
No cat or muffler.
A/F was rich at last dyno run (March?).
![](http://homepage.mac.com/jupeman/.Pictures/dyno_day/Tubbo_AFR.jpg)
The engine is running cool, perhaps too cool? It barely reaches the first tick above the double tick. I assume this is where the thermostat opens to the cooler. I have double coolers (no ac condenser) so I assume the thermostat opens/closes/opens/closes...
Pull the rubber inlet boot to your turbo... See if there is any oil present.. Have a leak down done.. Broken ring/guide wear? What turbo are you running?
