Whistling from a/c fan
Hey guys,
'92 Turbo: After about 10 minutes of running my A/C, I am getting a chttering
whistling sound coming from the center vent, or maybe from the fan itself...
Usually happens at fan speed 2 and disappears at lower and hight settings...
Anyone experience this? Any quick fix?
David
David
David,
if you are certain the sound is coming from around the centre vent area, then it must be the little fan at the back of the HVAC contol unit - it can be replaced lubricated with WD40 or replaced for about UK£80.
Best regards
Emilios
Best regards
Emilios
Mine did this also for a few months, Fan setting #2 only. It also spewed a bunch of crud (looked like paper covering or lining from the vent walls, not sure) onto the dash for a short time. I vacuumed the vents with a small hose attachment and it stopped making the noise. Otherwise it requires lubrication like Emilios said.
JBH had this problem and I sent him the manual info on removal of the fan for lubrication. I don't know f he ever resolved it.
