Lower Ride Height - Rear Control Arm Bushing
Can anyone shed some light on what exactly is referenced when installing bushings for a lowered setup?
I am assuming it is indexing the bushing for a 'neutral' position in the lowered state, however some additional information would be nice.
Was any special machining needed?
no machining needed. there is a nose a the front bearing. this is positioned straight to the nose at the lower trailing arm. for the turbo s they turned it a little 7‘ from this nose. this nose „venters the trailing arm and is stressed in lowered cars. so they turned it a little ….
