K27 High Flow installation
Is the K27HF a standard KKK turbo (or a modified one)?
Is there a model number like K27-2006 or is it just called K27HF?
(I want to find out if they are available here in SA and for how much)
Thanx
Daneel
Thanx
Daneel
DaneelV,
The HF turbo is a K27 Hybrid. In simple terms they use a stock K27 and modify the housing to accommodate a slightly larger 16 vein turbine wheel vs. the stock 12 vein wheel. The difference is amazing and I highly recommend it. I only know of two places currently offering a HF-K27. Try Stephen at Imagine auto. or Rick Deman at Deman Motorsports. They are both Rennlist members, one of them may be willing to ship you a unit depending on how difficult customs may be.
Good Luck
Good Luck
Since I installed my K27HF, I kept hearing a hissing noise - even at idle - which I had thought was perhaps more air of some sort being moved around by the new, stronger HF. This hissing sound could also be heard from inside the car.
Today I went to my mechanic just to double-check that everything was OK and in order (all vacuum pipes/connections/airfilter/turbo/intercooler pipes etc). Upon removal of the intercooler, we discovered to our amazement that the orange seal which seals the throttle housing to the intercooler was not seating properly / leaking and that was where all ther hissing sound was coming from. We replaced the seal, put everything together again and went for a spin - WOW - K27HF power in all its glory!
Really thrilled by all this power! Call me stupid but, I hadn't realised for almost a month that the car was not operating to its optimum - I can now tell the real difference, compared to my standard turbocharger.
Just wanted to let everyone know the importance of this seal, which -judging by all the threads on Rennlist- has given a lot of trouble to many 930/965 turbo owners.
Best regards
Emilios
Best regards
Emilios
Rennlist Lifetime Member
Daneel,
Drop me an email. We keep these units in stock and move a ton of them. I am also very use to shipping overseas and the customs. We can handle all the specifics. Don't forget, we are not only members, but also a sponsor
