Turbo running poorly
If the question of vehicle-specific adaptation is to be answered, at least the actual AFR values have to be known over the entire operating range.
Fritz
You will need a device like an Innovate LM-2 so you can actually see what the arf values are.
Idle - 14.0 to 14.5/1, engine warmed up
Boost - 11.0 - 11.5/1 at boost onset; 12.0 -12.6/1 at 6000 rpm.
If you don't come close to these values, you will have to back into them by tweaking control pressures to get there, IF the wur is adjustable (which I doubt it is).
You would raise control pressure to run leaner, drop to go richer.
Bottom line is you need afr data to pinpoint the issue as I'm not aware of any source for how an S2 was set by Andial. You might possibly need an adjustable wur (you can source one from RarlyL8.com).
But brfore we get to the tuning, there is still some troubleshooting to do in the way of establishing that you don't have unmetered air entering the intake or air being forced out of the system.
First check - when you turn the idle speed screw on the throttle body, does the idle speed change? If it doesn't, you most likely have a cracked injector block. This will require the intercooler, fuel head and intake manifold to come off so you can replace them.
Second check - If you can vary the idle speed, check that the cheap-*** worm clamps the factory put on the intercooler coupling are tight and in good shape (you should really replace them anyway with uprated clamps) and the o-ring on the throttle body is in good shape (as previously mentioned).
Do these checks and report back your findings.
This is going to be a sizeable project for you. Get ready.....
heliolps2 (09-29-2022)
Is your ignition advancing correctly? Vacuum line connected to the EZ69?
Car revving correctly while parked? Coil strong? Rotor Good?
Here's a link to that ignition on Rennlist with Black_hat info.
So seems like good news - we took intercooler off and in the process it was found to not be completely in place. Put it back on properly and now the issue seems to be resolved after brief test drive. Will try it out more this weekend, but seems this might have been an easy one. Hopefully not too good to be true but maybe it worked itself loose over time??? Is that a thing? Thanks again to everyone for the input.
ianbsears (10-03-2022)
I have a S2 Intercooler. they are huge and tough to fit sometimes. Mine is for sale if you know anyone missing one.
When you seat the intercooler over the o-ring (using the slickest lube you can find), make sure that the neck of the intercooler sits down on the big boss cast into the throttle body on the drivers side of the casting. If it's "home" it is covering the o-ring completely. From there the 2 attachment bolts should sit into their mounting fingers at full depth (to the bottom of the slot) and the bolt in the front of the coil bracket should line up with it's hole.
You'll never be on the boost enough on the street to take advantage of an S2 intercooler.
I bought a 3.3 S2 Engine in 1999 from Oklahoma Foreign. Message me if you are interested. It's obviously a signature part like Speedline Wheels
I think the Engine went in this Roadster. The intercooler came back to me on another one I bought back. It definitely makes these engines look tougher and run cooler.
So after more test runs today, the initial issue seems to be gone. I'm happy about that, but it really seems the the boost comes on later now than it used to. I believe it came on about 3500 before, now its about 4500 or 5k. Very smooth throughout the revs but more lag to my lag. Max at 0.7 bar per digital gauge. Maybe this is how it's supposed to be - anyone familiar with stock S2 that can comment?
My 3.6 is largely stock and the boost pressure starts at 3000-3500 rpm.
Since you haven't done anything except the intercooler, the problem will be there.
Look from the left side under the intercooler to the throttle body. There is a cast side ridge there, the bottom flange of the intercooler should rest on the ridge. Also check from the right side to see if the o-ring has squeezed out somewhere.
Fritz
Fritz
Waste gate bolt
HotRod that Waste gate, get yourself a long bolt. Sounds like it’s all going out.
I need a 1 bar spring, you probably too.
let me know where to buy one?
I was thinking Patrick motorsports
