Does the 964 turbo have a DME relay
Does the 964 turbo have a DME relay, I can only find a grey relay up front, in the fuse box, I believe it is for the the fuel pumps.
Is it this relay that is bridged so the fuel pumps can run, if so does ignition still need to be on or do pumps activate as soon as terminals 87 and 30 are bridged
As I said no DME , only fuel pumps relay R61. The pumps run as soon as terminal 30 and 87 are bridged, no ignition required.
A long two-pole cable with a toggle switch on one side, on the other two flat plugs. With this you can control the pumps comfortably from the engine compartment.
Thanks I found the R61 Relay, looks like it had been getting very warm, leg 87 and around the plastic it was a light brown colour]
Will get the pumps powered up and hopefully can check the fuel pressures.
