vibration
A month ago I bought my first 965 turbo ('91, 44000 miles).When I drove the car in the first week I felt a vibration while changing gears,when the engine was warm that vibration disapeared.
A few weeks later that vibration is totaly gone.
Is there somebody who knows what this could have been.
Thanks,
Christophe.
Thanks,
Christophe.
Rennlist Lifetime Member
You might want to check your motor mounts and make sure they are ok.
Also another issue is the dual mass flywheel. The ceters of them will come apart allowing them to rotate back and forth. What you end up is a vibration when the car is torqued up and you pull it out ofi gear. The flywheel will shake the two plates for a moment and you feel it through the drivetrain. If it gets really bad you will know.
