High-pitched wheezing sound when cold
I've just noticed that when I start my car cold (after sitting for more than a couple of hours), I hear a high-pitched wheezing sound out of the engine area that gets worse when I get on the throttle. After a few minutes, once the car has warmed, it seems to go away. I was pulling the car out of the garage and my wife was leaving. She told me the car sounds horrible - she's always been against this car.
Any ideas on what it might be?
Frank
1991 C2T - Michael B. of Imagine Auto's former car
Frank
Lifetime Member
Lifetime Member
Frank,
I have the same problem, but the sound only last about 15-25 seconds. It happens only when I don't drive the car for more than a few days.
In the course of a day, it happens only once. After that everything is back to normal.
I've traced my problem to the belt tensioner/sensor mounted on middle left and lower down near the fan housing. It has a small wheel on it. If the belt broke for any reason, this sensor will trigger the warning light on the dash.
I have had some success with spraying some wd-40 on this wheel. But if I left the car park too long I will hear it again, but very briefly. On mine, it happens all the time when not driving for a few days and not just on cold days.
Regards,
Sonny
Regards,
Sonny
If it is coming from the RR. right hand side of the car, I would add to what Sonny said the possibility of having to check out the "A/C clutch" (that's how they call it here.). I had mine changed after having the exact same symptoms, that only get worse with time.
