Converting to a 3.8L
Has anyone done this conversion?
I have been talking to ANDIAL about their "S" and 3.8L conversion and it seems that both power and reliability are quite good. I am in the process of planning the future of my 3.6 and would like to keep it close to factory production and parts. So far, the ANDIAL upgrades seem to be the same as the factory except for the headers. Does anyone have any recommendations?
The after market headers are lighter, shorter in length so if it's anything you should see power gains with the headers or at least the boost building up quicker, JMHO.
My personal opinon is that the 3.8l conversion does not add that much and can introduce additional issues. There are two types of conversions, thin wall 3.8 which slip into the existing case bores, and the thick wall 3.8 that requires maching the case bore. My opinion is that the thin wall is too thin for turbo applications and I would not use it. The thick wall 3.8 requires case machining, and to do it properly requires o-rining the case to keep it sealed properly. I think the 3.8l reduces engine longevity for a little gain in torque. You will also have CIS fueling issues to contend with as well.
Andials 3.6 to 3.8 conversion for turbo
ESTIMATE FOR COMPLETE ENGINE CONVERSION
3.8L from 3.6L 1994 S - TURBO
REQUIRED PARTS
Turbo S parts as previously listed
3.8L Mahle Piston and Cylinders, complete
Carrillo Connecting Rods
Lightweight flywheel and sport clutch assembly
Sport clutch disc
Misc. rebuild parts including engine and trans. Fluids
SUBLET WORK
Polish and Port Cylinder Heads, and balance components
including crank and rods. Install exhaust valve guides
LABOR
Remove and replace engine and transmission (not required if eng. shipped)
Power conversion including: rebuild engine to specification, blue print
for 3.8L specifications. Magnaflux oil pump, Dissassemble and reassemble clyinder heads, valve lapping etc. Upgrade turbocharger, change camshafts, install lightweight clutch assembly.
Install Sport Intercooler
Insall Fuel Enrichment System
TURBO "S" OPTION AND 3.8L ENGINE CONVERSION
OPTIONAL PARTS B & B Header System
OPTIONAL LABOR Polish case
Powder Coat Sheet Metal
Dyno Test Engine
Note 1-The C2 Turbo has a hybrid ignition system that combines traditional ignition with crank fire properties and cannot be converted to twin plug.
Andials S Package
1992 - 1994 Carrera Turbo S Package
Parts Sport Cams
Sport Intercooler (see note 1)
K-27 TurboCharger
Misc. Valve cover & exhaust gaskets, o'rings, hoses etc
Labor R & R engine and transmission
Install camshafts, turbochargers and intercooler
TOTAL "S" PACKAGE
Recommended Additional Performance Enhancements
Parts 1 Bar Boost Spring
Labor R & R wastegate and install spring
Install fuel enrichment system
Note 1. Sport intercooler is sold on an exchange basis only
REQUIRED PARTS
Sport clutch disc
SUBLET WORK
LABOR
Dyno Test Engine
Andials S Package
Parts Sport Cams
K-27 TurboCharger
TOTAL "S" PACKAGE
L8Apex,
I'd go for their S Package to be on the safe side.
However I dont think the 3.6 turbo S came with a 1 bar spring, it came with a 0.9 bar spring. Geoffrey am I correct?
L8Apex,
The Andial 3.8 with their recored intercooler (from the factory authorized S2 kit, but they cant say that) is my dream car.
It is not a big bump in displacement but when combined w the half point compression increase it should add well to the low to mid range.
I would stay w the .8 to .9 bar as 1 bar is to much with the biger compression.
I'd also have the manifold extrude honed to go with the best porting job possable.
However, for more power for about the same you could just go EFI if your existing P&C's are ok.
Still, I like the idea of a 94 3.8 CIS a lot. Very factory style & sellable latter.
To make a real killer CIS I would add mapable controles to the CIS & ignition system. I think Gumballa has a kit or the Racers Group Unichip can be added to the CIS for complet tunability of the A/F's and spark including management of the boost by RPM and launch control.
Using this approach you will be able to get the fuel you need using a combo of electronicaly reduced "control presure" and taking the O2 frequency valve to 75%. In the worst case, you may have to tapper the boost just a bit at higher rpms.
I'd keep the stock headers & keep your Fabspeed muffer setup or go to a custom Borla XR-1 muffler of 3.5" .
Get a C2 normal 2-5 gear set w a GT or Porsche Motor Sports limited slip for a truly maxed car.
Maybe a bit to crazy for most but few TT's will stand a chance if you can get the traction. Wow!
I want one!
Keith
I want one!
Keith
Let the games begin! What turned into a valve guide job has turned into "while you're in there" job! I decided not to go with the 3.8l conversion. Instead I am going with the "S" conversion. cams/intercooler/Cylinder head rebuild (port and polish), 1.0bar of boost with tial wastegate, fuel enrichment, hks ebc, lightweight flywheel and last but not least c2 gears with a gt limited slip from vision motorsports (thx keith). I will keep ya posted on any updates and progress reports.
What's the deal with the GT limited slip? Who are Vision motorsports? Are these an improvement over our stock 20/100's? Seems like I should probably change my lsd while I'm at it...it makes enough noise.
ian,
The shorter gears make the power delivery & car quicker. (think 6 speed) However, it does reduce the top speed by 15-20 mph. Which is more appropriate for guys in the US that never see that end of our speedo.
C4TT, I know Todd does some amazing work. However, I want to keep it close to factory "S" specs. When are you going to sell me your car? HEHE.
