MB power steering pump or rack problem
Forgot to add - have the electrical connection diagram for the MR2. Shows were power, ground and speed sensors are linked. The MR2 is an interesting unit as it increases output based on demand- i.e. if you are on interstate little pump activity, if you are running an auto cross more pump activity (increase in output)
Gus- That’s some great info and the first time I’ve seen a cooler installed. Do you think the pump could fit over the abs pump? I’d like to be able to keep the trunk area as clear as possible for luggage and track stuff.
Thanks!
Pete
Thanks!
Pete
