Original hose was barrier hose per the research I did at the time. Its not like the stuff from the much earlier aircooled 911s. I had the hoses in the engine bay rebuilt using Parker FUTURA hose at the local hose shop.
Barrier hose was introduced mid-year 1992. My '91 Turbo didn't have barrier hose. When I refurbished my system in 2020, I had all lines refurbished with barrier hose.
As for condensers, I bought a parallel flow one from Griffiths Technical. To get it to fit I had to mill down the rest pad welded to the bottom header and add a bolt hole to the sheet metal bracket on top. Easy peasey.
Is there a way to tell if my 92 has barrier hoses? Is there a marking on the hose or is there a build date that they started from?
You might be able to do it by measuring hose diameter. I recommend calling Griffiths Technical and talking to them about it.
Somewhere in the engine compartment there should be a sticker stating what the system was charged with.
Mine was charged with R12 as it came with r12 ports on the compressor and no r134a ports on the hose manifold. What diameter should I have with one hose or the other?
I don't know about the diameters but you definitely don't have barrier hose if that's the case.
So a simpler and less confusing to just say that they switched refrigerants in the 92 model year and cars that got R134a received barrier hoses. It’s a bit more clear.
My understanding is that is that in '92 it was a mid-year changeover, so not simple at all.
Given that your car is outfitted with R-12 ports, it was most likely built out that way.
In any event, 30 year old A/C hose might have already failed or is getting ready to.
