964 Forum 1989-1994
How do I remove this HVAC servo?
Old 05-21-2017, 12:26 PM
kylejohnston1
kylejohnston1's Avatar
Default How do I remove this HVAC servo?
The servo shown in the attached pics has me baffled. It is the one all the way at the far right in the picture (driver side here in the US). Seems like the screws to remove are only accessible from underneath the servo.
Any advice on how to remove this one? Thanks!
Old 05-21-2017, 03:16 PM
JohnK964
JohnK964's Avatar
They are under the ac line In Your photo
Old 05-21-2017, 03:33 PM
JohnK964
JohnK964's Avatar
Below these arrows
Old 05-21-2017, 05:17 PM
mojorizing
mojorizing's Avatar
To remove that servo, loosen HVAC hose bracket to the right of the yellow connector holder, disconnect linkage arm, remove the screw that is through the slot on the plate, then remove the plate/servo forward and to the side. That plate has a tab which engages a slot on the plastic case of the HVAC.
Old 05-21-2017, 05:28 PM
mojorizing
mojorizing's Avatar
Circled is the tab on the plate and the slot in the case. Also see the 3 screws that attach the servo to the plate - not accessible at all.
Old 05-21-2017, 05:34 PM
kylejohnston1
Thanks for the great info mojorizing and JohnK964! I probably would have fidgeted with this for hours without the notes and pics above.
Old 05-21-2017, 05:42 PM
JohnK964
JohnK964's Avatar
Quick Reply: How do I remove this HVAC servo?
