Just finished my rebuild/reseal and thought I share a video :)
#32
It looks like you inserted head studs before doing the perimeter nuts etc while closing the case. I barely made the 45 minute mark even with just the through bolts and perimeter nuts, or is there a sequence jump.
BTW: If one of you graphic designers in this forum came up with a DIY 911 engine rebuild decal I'd buy it, when I'd finished and qualified for it. The sobering part is that your video suggests that I'm only 10% along the way
#33
Ronone10, for sure we should hook up if you're around I always enjoy seeing other 964s and meet their owners. I'll provide the beer bro.
I barely made the 45 minutes mark too. It was the most stressful part of the build. Damn just thinking about it stresses me out.
#36
Thanks. I'm doing the cylinders this week and Curil T makes the most sense as it's non hardening.
Btw I read you are almost past the break in period. I have 15 litres of running in oil ready for mine. How many changes have you done so far and how many more before you are in a normal sync? I'm mostly concerned about the residual oil in the system both during and after running in i.e. I don't want synthetic in there for the running in period or non detergent after it. I figure each oil change ends up in a ~ 70/30 new old mix. I may change my running in oil after the 20 minute run at 2,500 rpm to end up with 90% running in oil.
#38
I changed the oil in the first 20 minutes after starting engine. Then drove the car for a few hundred miles changed oil again. Then at 1000 miles I did valve adjustment and final break-in oil change. I'm running Mobil 1 0-40 synthetic now.
#40
Great video...this may just inspire me to do the same. I'm going to review your jack stand dismount again as I'm not quite sure I understood everything that went on there.
