Question: Sunroof Delete
I'm in the process of doing a complete repaint with a sunroof delete. Body shop wants to reinstall sunroof substructure for strength but that defeats some of the reasons for deleted namely head room clearance and weight.
Car will only be D.E.'d occasionally so it's not a race car. Thoughts? Anyone removed everything and welded in the panel and been satisfied over the long haul regarding paint integrity etc?
I believe Larry Kosilla from AMMONYC just did the exact same thing you are attempting to do!! His 964 is a track car as well.
Try www.ammonyc.com to contact directly.
I had mine done three years and 20k miles ago. I had all the sunroof removed, ground round the opening, cut the tabs on the sides and peeled it all out then had a panel welded in. It looks great and there is absolutely no way to tell it ever had a sunroof. As long as your tactical when you weld the panel up the tension comes back into the roof.
If you're removing the sunroof for weight I'd say go for a carbon fiber top vs welding. I have this on my list and found a good source for Carbon fiber on pelican parts forums.
No affiliation http://forums.pelicanparts.com/porsc...-skins-fs.html
It was a fenn lane Lane panel I used. Not as bad a job as many had made it out to be, getting the headlining perfect was another story! Took me a while to realise both the inner and outer skins are joined all the way around the opening! It's also a good opportunity to strip and paint both window surrounds and the front scuttle.
Second the Fenn lane panel. It was a bit of work but worth it. The roof is a flimsy piece when the sunroof is removed. We welded the entire gap and even abusing the car on it on track it will never be a problem.
Worth the money and they give you the templet to make sure the roof is curved properly which is important.
OP,
Also a good past thread: https://rennlist.com/forums/964-foru...e-sunroof.html
Have you thought about the rain gutter delete option?
![](https://rennlist.com/forums/attachments/964-forum/472682d1283883417-2-336-9-pound-street-legal-964-ap-design-964-cupintro.jpg)
![](https://rennlist.com/forums/attachments/964-forum/472687d1283883442-2-336-9-pound-street-legal-964-ap-design-964_cup_6detail_gr.jpg)
Or, a flush rear window?
![](https://rennlist.com/forums/attachments/964-forum/671451d1350061465-deleting-the-sunroof-r12.jpg)
![](https://rennlist.com/forums/attachments/964-forum/671452d1350061499-deleting-the-sunroof-r13.jpg)
I really want to follow your lead on the sunroof delete. Thought has crossed my mind lots of times - I never use the sunroof and the exterior view of the frame is not aesthetic to me. Wonder about impact on value? I'm sure a quality job will have little impact if any.
Assuming no broken windshield and all the rest involved you will never see that money when you go to sell. Then no doubt it all depends on how factory the finished product looks.
I also would not consider anything but a metal panel welded in place unless you plan to install a roll bar or cage. Even as a dedicated track car with full cage I went with the Fenn lane panel because no matter how nice the job the glass or CF panels never look perfect to my eye. I am a bit picky though. Another concern is depending on the replacement panel used these can buffet in the wind and cause noise in the cabin.
Just removing the sunroof saved something like 54 pounds IIRC not sure what a glass roof will save but it wasn't enough for me considering the cons.
+1 for the Fenn Lane panel.
Perfect fit and totally imperceptible from a factory non sunroof car, as long as fitted by a competent body shop
Regarding the headliner. I used lightweight felt and glued to the inner roof inside the inner frame, similar to the 911 R, pretty simple job
or is it very much like this? (with neater edges
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/800x450/liner_roof_6780e0172f8a5c7266fe2fe87e658709480a612b.jpg)
