964 Forum 1989-1994
Air intake manifold ?
Old 04-01-2017, 02:43 PM
Jjm4life
Jjm4life's Avatar
Originally Posted by Talat
This is what I'll be doing shortly - Rothsport EFI with AEM Infinity. Basically the same setup as the Bisimoto 911R. Went with AEM since it's the only ECU with knock control within my (increasingly out of control) budget. May add cams but not sure yet. Will start a thread once the work starts - I'm hoping to do a before and after dyno run.
I saw bisimoto is selling aem infinity and a 3.6 specific wiring harness. Looks like a solid deal.
Originally Posted by Steve Weiner-Rennsport Systems
We prefer Motec for its quality, durability, and support. Naturally, software familiarity is everything and thats one of the key factors in choosing Engine Management. One of our employees has made the commitment learn this system and is a true wizard with Motec.
JMHO, there seems to be far more people around the country who know Motec more than any other racing Management system and thats a big advantage, depending on where you live.
Thanks Steve. I assumed familiarity had a lot to do with the choice. Once my wallet recovers your ITB setups is on the top of my list
Old 04-01-2017, 04:36 PM
Super90
Super90's Avatar
I would love to go Motec. The only downside.....cost ! : )
Old 04-02-2017, 09:47 AM
eddieb4
eddieb4's Avatar
Steve,
Couple of quick questions if you don't mind:
1) Cost of this set up?
2) Is same setup recommended for a 3.8?
3) LWFW ... would a chip (wong) still be necessary to keep car from stalling?
I am in the process of a 3.8 build and wonder how much more this setup would cost and is the power increase additive to the bump (modest) that a 3.8 brings to the table?
Old 04-02-2017, 10:29 AM
Jjm4life
Jjm4life's Avatar
^^ i can't answer 1&3, but the new Ecu replaces the factory Ecu/chipped setup. In. Addition to the new Ecu, you need someone competent to write a new map for it.
Old 04-02-2017, 02:11 PM
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Originally Posted by eddieb4
Steve,
Call me during business hours.
Too many complex questions here that require a detailed reply.
Quick Reply: Air intake manifold ?
