Windshield Installation - Adhesive?
Had the windshield replaced in my '91 back in November, a nice new Pilkington with OE seal. Fits and looks great!
However, it wasn't glued in (per the shop manual). One of the previous owners had the windshield out when the cowl was resprayed, and that's how the shop put it back in.
What type of adhesive does Porsche use, standard urethane? Is the OE adhesive (000-043-204-82) anything special or standard fare? A local glass shop does classics and I'm looking into having them do the re-install properly (so I can get the upper dash back in).
I see no one has answered this. IIRC the 964 was the first 911 variant that didn't have a glued-in windscreen from the factory.
Again, IIRC there are some who do glue in the replacements.
Finally, and again IIRC [
] there was some chatter on the Pelican 911 forum (not the 964/993 forum) about using the new screen/seal in the old cars and adhesives were discussed. Might be worth a look.
I took a look between the 964 PET and 993 PET, and both reference the same adhesive items for the windshield installation. So it looks like it's urethane, then.
The local shop wants to squirt the adhesive under the seal on each side without removing the whole thing first.
FWIW, mine doesn't leak and it's noticeably quieter than the old windshield. It's that I'd like for it to be done per the manual.
Do you have a set of 964 workshop manuals? The procedure is in the Body book under pages 64-1 to 64-7. It lists the steps for windshield removal and installation including the use of adhesive.
Adhesive = 999-915-400-40
Appreciate the input, guys.
I just had the windscreen replaced on my 964. There was glue that was quite a pain to remove and as with the OP, the shop installed the new windscreen without the adhesive.
As Rocket Rob mentions above, the Porsche workshop manual clearly instructs to use adhesive in the installation, but I have read arguments that the use of the adhesive is more likely to cause rust issues than to reduce them and hence there is no reason to use the adhesive. This is also the argument from the shop that installed the new windscreen on my car.
The obvious benefit of not using the adhesive is that changing the windscreen in the future is much easier., but would anyone know if there is any merit to the above rust argument or not? Also, is there any other reason to use the adhesive? Does it increase structural rigidity? Reduce noise? Is it necessary to secure correct airbag deployment? Or any other reason? I guess another way of asking is whether or not there is any downside in leaving the adhesive off?
The shop that installed my glass is willing to remove the glass and seal and put in the adhesive at no additional cost to me if I insist, but they do not recommend it. The Porsche instructions in the workshop manual on the 964 are more than 20 years old - would the recommendation from Porsche be the same if the instruction was written today when the rust issue is more common knowledge? So as the OP, I am wondering what should I do...
I have an BMW E30 M3 (1987-built), and it has a bonded windscreen from the factory --- the other E30 models do not have bonded windscreens.
The bonded windscreen in the E30 M3's was touted to increase rigidity, although I forgot what the percentage increase in torsional rigidity is...?
I would assume that this is why 964's have them bonded in. Similar era of manufacture, so it stands to reason.
Regardless of the reason, though... they ARE bonded in. So the Correct (big C) way to install one in a 964 is to use the adhesive.
to Op did you reinstall your windshield with the pn 000-043-204-82 . I am wanting to install my windows all the way around and have been confused as to which adhesive to use. If you search pelican parts as an example it comes back with a Mercedes product but the pn above comes back as a Wurth product
Thank You
Thank You
I've had all my glass replaced dry, without sealant. It recently made installing my RS spec carpet easy. No leaks at all. I don't recall my qtr glass having any signs of sealant from the factory. The original rear glass had something like butyl. The front windshield had been replaced sometime before my ownership and it was dry.
