From airbag steering to Sport !
Guys,
First question
I can't find the full review how to change my airbag steering to simple momo wheel.
Should I need all this stuff ?
- NIB Momo 7004 hub/parts/instructions for 993/964 (and others, but the following parts are for 993/964)
- Horn contact ring 964.652.104.00 (allows horn connection after you remove airbag clock spring)
- Female Molex connector 999.652.639.22 to connect horn contact to old wire (see DIY)
- 2.7 Ohm 1/4 watt resistor to fool airbag module (and a spare)
Also maybe smn have full tutorial how to change , I check all threads and only text without photos of process ;((
The most tricky part for me is how to attach wires and not,to have airbag light and should I need L button like on 993 ? I found photo in other thread, so should I need to buy all this stuff ?
Second question
I found this kit , should I need to buy extra parts ??
http://www.fvd.de/de/ru/Porsche-0/35...__Ø350_mm.html
First question
Second question
There is an OEM Bridge Plug for the warning light... PN 928-612-220-00
