Changing pedals covers ?!
Hi Guys,
What "sport cover pedals" you recommend , as I understand I need to make holes to attach the new one?
Should I install above rubber pedals ? Or I need to detach the rubber?
Also how to attach dead pedal.
I mean smth like this
http://cf-design911-2.datadial.info/...60720911lr.jpg
No tutorial ?
No tutorial ?
Hi Guys,
No tutorial ?
No tutorial ?
I have these pedals from Rennline which are similar to the design911 set. Installation is not difficult. You can find installation instructions here: http://www.rennline.com/PDF/p-perf.pdf
Good luck.
Thanks.
As I understand Accelerator pedal don't have rubber pedals pad which I must remove like on Clutch and Brake pedal?
So I must drill it with rubber on ?
The accelerater pedal is plastic, I think. And, yes you must drill it & attach the new pedal over it.
