Wheels setup for 964 Turbo ?
Guys I am tired of searching wheels ;((
Need you professional advice.
My car 1994, 964 3.6 Turbo
I am searching for the closest look of 3.8 RS wheels with deep effect of the rims especially rear one .
I found RH wheels with different offset , can smn advice which to take to have a close as possible with 3.8 RS? To fit without any modifications to my car.
For front and rear ! Will be very appreciated for help because instead my head will blow off with searching ;(((
1)
18x8.5 ET 21 (5x130) 71.6 Centre Bore
18x8.5 ET 46 (5x130) 71.6 Centre Bore
18x8.5 ET 59 (5x130) 71.6 Centre Bore
2)
18x9 ET 15 (5x130) 71.6 Centre Bore
18x9 ET 2 (5x130) 71.6 Centre Bore
18x9 ET 40 (5x130) 71.6 Centre Bore
18x9 ET 52 (5x130) 71.6 Centre Bore
3)
18x9.5 ET 33 (5x130) 71.6 Centre Bore
18x9.5 ET 47 (5x130) 71.6 Centre Bore
18x9.5 ET 59 (5x130) 71.6 Centre Bore
4)
18x10 ET 15 (5x130) 71.6 Centre Bore
18x10 ET 40 (5x130) 71.6 Centre Bore
18x10 ET 54 (5x130) 71.6 Centre Bore
5)
18x10.5 ET 33 (5x130) 71.6 Centre Bore
18x10.5 ET 59 (5x130) 71.6 Centre Bore
6)
18x11 ET 28 (5x130) 71.6 Centre Bore
18x11 ET 40 (5x130) 71.6 Centre Bore
18x11 ET 52 (5x130) 71.6 Centre Bore
18x11 ET 65 (5x130) 71.6 Centre Bore
7)
18x11.5 ET 33 (5x130) 71.6 Centre Bore
18x11.5 ET 59 (5x130) 71.6 Centre Bore
On their website they advice to take
8,5 x 18 ET 46 (225/40 R18) will 235 fit in ?
11 x 18 ET 52 (285/30 R18) will 295 fit in ?
What do you think ?
1)
2)
3)
4)
5)
6)
7)
What do you think ?
Here's the thing - the 3.8 RS has, I believe, narrow body trailing arms so the wide wheels have a much deeper dish than the wheels on the Turbos, which put the hubs further outward than the narrow body cars - to help fill out the wheel flares. Even tho both are Speedline.
Can't go wrong with the OE Speedlines - GREAT looking wheels.
But from what specs which I listed the closest look , with which fitment will be close ?
I understand that it can't be the same like on 3,8 RS , but the closest look with which setup ?
I fit the factory 9.5 ET 57 RSR wheels up front however you are limited to a max of 10.5 ET59 in the rear with rolled fenders and careful measurement of your car as they vary.
I would probably consider a max of 8.5 up front if you use a 10.5 in the rear. Of course this is also dependent on not only the size but the make of tire as they vary in sidewall and dimensions depending on manufacturer. Suspension setup will also make a determining factor on what fits.
