Dangaling Cable!!! HELP
HI,
Ive just topped up my Oil, and while I was in the engine bay I just took a little look around.
To my suprise as you look into the engine bay, on the left hand side, quite deep in I found a cable hanging! it comes from the engine bay rear wall with some other cables. It is a kind of plug, and is circular rubber construction with 3 female connections and 4 male connections, set in a ring pattern. its about 300mm diameter.
Does anyone have a CLUE what this could be and what it should be connected to??
Thanks,
Martin
Thanks,
Martin
DAMN,
I searched before I posted and did'nt pick it up because of the term 'wire plug' i'd never thought of calling it that!!!
Thanks anyway........ i'll catch up soon
