Porsche 964 Oxygen sensor and Open loop problem
Hello everyone,
I have my engine running on a test stand while the car is being completed. Here is the current configuration of the engine:
Stock intake
Cone filter
all new fuel injectors - tested
light weight flywheel
B&B headers
New pistons and cylinders
ECU jumper in place for "USA Japan with Cat Converter" (so O sensor is in the loop)
.03 ECU with Steve Wong chip
So, here are the symptoms:
- engine starts immediately with a touch of the key
- no faults or errors
- idle is perfect
- about 60-90 seconds in it begins to idle very rough and smoke (rich)
- Put stock chip back in and same symptoms.
It appears to go into open loop.
- So, I replaced O sensor and symptoms the same
- monitor voltages from O sensor and it points to 'very rich'.
- Disconnect O sensor and no CEL or error appears. This seems odd to me. Can someone confirm that I should get the light by unplugging the sensor?
Now, if I change the ECU jumper so that it corresponds to "Manual trans without Cat converter" the engine runs fine. This eliminates to O sensor from the system.
I have checked all wiring to ECU for the O sensor - all ok
It just comes down to the ECU seems to not recognize the signal from the O sensor.
Should I just leave the O sensor out?
My guess is that there is something internal in the ECU that is the problem -
Any thoughts?
Stock intake
Cone filter
B&B headers
- idle is perfect
Any thoughts?
Both coding plugs should have no jumpers for "USA Japan with Cat Converter".
Which pins are you putting the jumper on? If you are jumping the 3-pin to ground, then you're getting open-loop always. If you're jumping it to +12v, then you're getting the Japan map that uses a cat temp sensor. I'm not sure what the latter mode looks at/for. Sounds like you are jumping to ground. Which would explain why there's no cel when you unplug the o2 sensor- the ecu isn't expecting one!
My jumper chart may be off so this is what I have:
- Manual trans with cat, Except USA and Japan - open
- Manual trans, USA and Japan - jumper to 12v
- Manual trans without cat - jumper to ground
So I put the jumper to 12v and get the rough idle etc after 90 seconds. I put the jumper To ground and it runs fine but I assume no O sensor.
Am I off here? What should I have for the use of O sensor?
Found a post by Bill Verberg...
1. for 964 manual w/ cat - 2 pin is open and the 3 pin is open
(all USA except California)
2. for 964 manual Japan the 2 pin is open and the 3 pin is bridged to battery+ w/ 928.607.421.00
3. for manual w/o cat the 2 is open and the 3 pin is bridged against ground w/ 928.607.422.00
So it looks like I need to open up everything and the O sensor should work (and give a cel when disconnected).
Here is an update:
after making sure that both the 2 pin and 3 pin connectors were open, I started the engine and let it run for a couple minutes.
I then unplugged the oxygen sensor and the Check Engine light did not come on.
Can someone confirm that this should happen? i can get any other fault and clear it.
Thanks,
Thomas
Thanks,
Thomas
Technical Guru
Take a look at THIS THREAD! To switch to the USA fueling maps and have the ECU pay attention to the O2 sensor requires a jumper to 12V+ using 928.607.421.00. The way you are setup now will set the ECU to ROW + CAT. Does your check engine light illuminate when you disconnect other sensors? Have you tried going back to the stock chip?
