964 Forum 1989-1994
Oil Pipe Identification Please
Old Apr 21, 2016 | 07:36 AM
Evil Bunny's Avatar
Evil Bunny
Default Oil Pipe Identification Please
Could anyone confirm what item number on the PET the oil pipe in the picture is?
It is the rigid pipe that runs through the rear wheel arch.
Second question would be around a replacement, has anyone fitted, a stainless steel equivalent? - I hate corrosion!
File Type: jpg
File Type: jpg
Old Apr 21, 2016 | 07:45 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
That's #24 on the PET drawing.
And are you sure you have corrosion and not paint failure? Many of these oil pipes are brass.
Old Apr 21, 2016 | 07:52 AM
Evil Bunny's Avatar
Evil Bunny
Rob, many thanks for the confirmation.
You raise a good point regarding the corrosion, this warrants further investigation prior to a trip to my OPC!
I have no leaks, but was looking to be preempt any failures to avoid the potential mess and pain of being stranded!
Old Apr 22, 2016 | 01:25 PM
deadendd9009's Avatar
deadendd9009
Just make sure your rubber lines are in good shape and that connections are tight. That pipe won't give you issues.
Old Apr 22, 2016 | 01:47 PM
FormulaRX's Avatar
FormulaRX
I've been curious about that exact pipe. I have no leaks tho. Just looks like the paint is corroded but I want to change it just in case
Old Apr 22, 2016 | 01:59 PM
RW964's Avatar
RW964
Default Oil Line I D
Hey Evil Bunny I have changed out oil lines in the past but not all of them so to keep track of what lines were done I copied this print and highlighted the oil lines replaced in red and dated at the bottom. So later when changing out more lines I can see fast what I have done. Hope this helps
Old Apr 22, 2016 | 02:53 PM
Super90's Avatar
Super90
I love the tight record keeping !
I just finished replacing every hose or rubber piece on that entire page of the parts catalog ! : ) I figured it's all 25 years old, so, the old girl deserved a little TLC.
Old Apr 22, 2016 | 03:32 PM
CRG's Avatar
CRG
here's a tip o the day ref record keeping- download the PET, go to the page you are referencing, got to the top toolbar under "tools" hit "annotate" and choose oval then circle every part in the diagram you are replacing. it won't help you with $ spent (prob a good thing) but to keep track of the parts/pieces replaced or repaired it's a groovy way to keep track of work done.
My PET is covered in red circles...
Old Apr 23, 2016 | 08:57 AM
deadendd9009
If corrosion is your concern, you could have it sandblasted and powdercoated, it'll be good as new and will only cost a few dollars.
