Gas Pedal Replacement
I am looking for an aftermarket gas pedal to replace my stock one (not an overlay) which will align better with the brake to allow for proper heel toe. I know Hargett used to make one that could be adapted to fit a 964 (no longer producing them, too bad this was my first option), and Rennline makes a fully adjustable one. My problem with the Rennline is a silly cosmetic bias, I simply don’t like the look of it, particularly the two separate pieces that make up the pedal. What other options are out there?
Left or rhd?, 993 box or 964? All the pedals are height adjustable, you can lower the brake. I have the 993 rhd box and moved my throttle pedal across, and cut a section out at the top edge. Works well now
What he is looking for is this...not an overlay.
Does anyone know of an alternative to the rennline fully adjustable pedal, now that Hargett no longer makes this pedal? I wish they did. This was the best upgrade I ever made for my car.
They still have it on the site, what happens when you order?
http://hargettprecision.com/index.ph...als/rxgpa.html
Real bummer. They made the best one hands down.
Maybe if a bunch of us call them we could do a short run?
Who's in for the "right" adjustable pedal?
Let's see if we can get an order of 20 or so globally...
