964 Forum 1989-1994
oil pipe under rear wheel arch
Old 10-09-2003, 09:46 AM
ian c - u.k
Registered User
ian c - u.k's Avatar
Default oil pipe under rear wheel arch
what size spanner to remove the nut on this ???
36 mm. ????
Old 10-09-2003, 12:03 PM
Jeff Curtis
Jeff Curtis's Avatar
Default Actually...
...you are correct, partially anyways.
With the assistance of a 32mm wrench, your job would go a bit easier.
Use them in conjunction with each other or your will surely unscrew the tap fitting from either your thermostat or remote oil filter mount block.
Good luck, it's a tough job busting that one loose...watch your knuckles!
Old 10-09-2003, 03:07 PM
gjvander
gjvander's Avatar
I vote for removing the whole oil filter mount block. I recently had to remove the engine, and that was the easiest way to loosen up the big nut.
Once it is loose you can easily slip the wrenches on the nuts.
Regards,
Geo
Old 10-09-2003, 04:10 PM
Jeff Curtis
That is actually a VERY good idea Geo...I have done that before as the first time I went to "wrangle" that line off, it seemed impossible.
Good thing you suggested that - Ian, I 2nd that vote!
Old 10-09-2003, 04:23 PM
johnfm
johnfm's Avatar
Ian
just be really careful to thoroughly clean all the ****e (a northen word for you US listers!!) from under the wheel arch. If that ****e gets into your oil pipes, its in your engine.
Old 10-09-2003, 04:32 PM
Wikkid911
Remarkable
Wikkid911's Avatar
[QUOTE]Originally posted by johnfm
Today has been a very amusing day at Rennlist world.
Old 10-10-2003, 12:08 PM
ian c - u.k
Registered User
thanks boys !!
1st job tonight is to nick a 32mm spanner from work to go with the 36 i allready had away
Old 10-31-2003, 06:55 AM
Youcef
Youcef's Avatar
The oil feed lines on my C4 are leaking at the oil filter mount block, does anyone know if these fittings have an olive seal inside or must they be replaced completely to make a proper seal?
Old 10-31-2003, 01:54 PM
ian c - u.k
Registered User
no olive if i remembeer !!!
i'd loosen joint , clean faces , and reseal with big spanners !!!
Old 10-31-2003, 02:58 PM
Jeff Curtis
Yup, I concur...then verify if they are in fact leaking from where the hose is crimped into the metal connectors.
...Aaaaaah...the joys of owning such a FINE automobile.
Old 10-31-2003, 03:39 PM
Jeff Midili
Jeff Midili's Avatar
Ok, I give up: what's an 'olive seal'? This is what Google says it is:
Olive Seal
But I'm pretty sure that's not what we are talking about.
I have a leak in this area too that I want to take some pictures of and post, just thought I'd get a head start with the learning curve.
Jeff
Old 11-01-2003, 01:55 PM
ian c - u.k
Registered User
in an "olive" compression joint , you will have the fitting body
tightening nut
olive !!
the olive goes over the pipe , and when the nut is tightened onto the fitting , the olive compresses onto the pipe , making the seal (hence the term compression fitting)
it is normally shaped like a wedding band (ring) , though some have 2 parts .
Old 11-03-2003, 10:50 AM
Jeff Midili
Thanks Ian,
Since I just hooked up a dishwasher last weekend I know exactly what you are talking about!
Jeff
Quick Reply: oil pipe under rear wheel arch
