What are differences between:
993 C2/C4 993.351.421.00 and 993 TT (993.351.425.10) front caliper
Are the fixation (bolt position or diameter) different
Can the first one be used on 322X32 disks
Thanks for any reply
Cheers
Cheers
They both have the same 130mm bolt pattern, mounting face height, the same 132mm pad length and the same 36/44 pistons, The 993RS/tt 'Big Red' pad is taller by ~4mm the pads heights are ~175mm for 993RS and ~171mm for other 993. The 993 uses a 304x32mm rotor the 993RS/tt uses a 322x32mm rotor
Hey my friend
Brake questions are you specialty ;-)
What are the performance difference when mounted on a 964. Are we talking about 5% or 50%
Is it worth the money to mount 322 and pay $500 more for the RS caliper.
Can one achieve the 1.43 torque ratio when using the 993 C2/C4 components?
Hey my friend
For a 964 upgrrrade there are 3 ways to go, w/o losing the parking brake all use a regular small 993 rear caliper and either stock 964 or 968M030 rear rotor
1) 993 front caliper on 928 S4 304x32mm rotor
2) 993RS big red caliper or 928GTS big black front caliper on 322x32mm rotor
3) 964RS/t black caliper on 322x32mm rotor, an alternate caliper here is 993 front caliper this is the same as was use on 964RS/Cup
Here are the torque bias ratios
1) 1.604
2) 1.659
3) 1.713 the 993 or 964RS caliper develops more brake torque than a 964RS when both use the same 322mm rotor
If it were my car I would remove or gut the p/v w/ any of these setups as they are all a little more front biased than is necessary.
Question, if I have a 964 C2 and upgrade to 993 C2 front caliper, can I retain the stock 964 rear caliper (can this setup be made to work with a different p/v)? If I have to use the 993 C2 rear caliper, what p/v do I need?
^^^^ I'm also looking for an answer to that question. If it matters I have a '90 964 with stock brakes but have a full set of '95 993 calipers and rotors (front and rear). I'm wondering how difficult is the conversion to the black 993 calipers and rotors. Thanks.
You can, it's not dangerous or anything just a misallocation of resources to the front, If you use 993 front and rear it's way better and approximates 964RS
You can leave the stock p/v or do as the 964 Cups did and remove the p/v entirely. Any of these setups have lots of front bias and don't really need a p/v
the 993 rotor won't work on a 964 at all
the 993 front calipers just need a caliper adapter and 993 rear calipers are a bolt on w/ stock rotors.
for the front rotor 993 wants 304 x32 rotor, this is the same size rotor as 930s used but you will need a custom hat and annulus. You could use the stock 993 rotors if you also use a 993(or 993RS) wheel carrier, w/ this setup you no longer need a caliper adapter as the 993 calipers bolt directly to the 993 (or 993RS) wheel carrier
