964 Forum 1989-1994
Porsche Immobiliser
Old Mar 15, 2016 | 10:32 AM
Haves1979's Avatar
Haves1979
Default Porsche Immobiliser
The standard fit Porsche immobiliser (with the USB style key) on my car is getting a bit temperamental. The keys seem fine, however the socket appears to be getting worn and it some times takes a few attempts for it to work. Is the usual route to go for a repair, or just remove it? The car is getting a new alarm fitted next week anyhow so I'm unsure if to ask them to just pull the lot out when he removes the old alarm system. Any pointers appreciated, cheers.
Old Mar 15, 2016 | 10:45 AM
ToreB's Avatar
ToreB
The immobiliser fitted in UK cars is a PA1000 or PA2000 type, made by Hamilton and Palmer in the UK. You could call them for tips and help. Removing it will probably involve a lot of rewiring. The guys on the 993 forum on 911UK.com could probably provide more tips.
Cheers,
Tore
Old Mar 16, 2016 | 05:02 PM
Haves1979's Avatar
Haves1979
Thanks i have spoken to Hamilton ana Palmer and it's about £50 for a new socket. However for peace of mind I've decided to just pull out the current system and immobiliser and fit a new category 1 alarm and immobiliser.
Cheers
Old Mar 17, 2016 | 05:03 AM
time666's Avatar
time666
Hi Haves1979,
That's what I did, as I have a few problems with mine, just replaced alarm with a Toad ai606 alarm cat 1 which had the immobilisation built in. This seemed to get good reviews.
My auto elec did the job, and it was only in for a few hours, just a number of writing harnesses removed.
Only thing I would suggest, if like my Hamilton alarm version, I had a relay in the rear electrical box which was used to cut power to the coils, best that this cheap relay is replaced with new at the same time. I would not re use the old one.
I suffered from intermittent starting issues, after replacing dizzy cap, ignition coils, DME relay, I finally traced it to this relay. The alarm was telling the relay to switch, but the relay was old and dropped out which cut power to the ignition coils and hence about 6 months of chasing, and replacing likely parts then the £10 relay....
