Weird Seat belt light issue
Took the 964 for the 1st time this spring and noticed a weird issue with the seatbelt light. It was flickering as I was driving. It seemed to go out when I pushed on the clutch, then I noticed that it would flicker when I step on the dead pedal area. I noticed this all while driving. When I got home I took a look at the footwell area and didn't notice anything. Then I noticed when I would lean on the seat the light would flicker. I pressed on the seat near the seatbelt and the light would flicker again. I reached under the seat and jiggled the wire going to the seatbelt and pressed up on the seat now the light is not flickering.
Is there a switch built into the seat. Im just wondering what was loose or not working correctly to cause the seatbelt light to flicker. Any suggestions.
