964 Forum 1989-1994
diff lock switch delete
Old Feb 24, 2016 | 11:42 AM
biggynuts01's Avatar
biggynuts01
Default diff lock switch delete
I am considering removing the diff lock console switch and replacing it with a cubby. I never use the diff lock switch any way. My question is does anyone know if removing the diff lock switch cause the pdas to be disabled?
Old Feb 24, 2016 | 12:22 PM
tdiquattro's Avatar
tdiquattro
You can run without it, no issues. I am doing the same, but rewiring to use a rocker switch above.
Old Feb 24, 2016 | 01:25 PM
biggynuts01
So the traction control stays activated without the switch installed?
Old Feb 24, 2016 | 01:33 PM
DobermanDad's Avatar
DobermanDad
Think so, but you'd also loose the ability to disable it without a switch.
Old Feb 24, 2016 | 04:05 PM
tdiquattro's Avatar
tdiquattro
Yes all still active, no switch installed, just unplug from the round connector.
Old Feb 24, 2016 | 05:10 PM
biggynuts01
Awesome thanks guys. This gives me some ideas. I may wire a different type of switch in a different location.
Old Feb 24, 2016 | 06:42 PM
tbennett017's Avatar
tbennett017
The switch only functions to lock all diffs up to 40 MPH. AND if you hold it in the on position long enough, it temporarily disables PDAS
