964 Forum 1989-1994
Fitting sports cat
Old Feb 24, 2016 | 09:08 AM
ChrisG89's Avatar
ChrisG89
Default Fitting sports cat
Hey,
I'm going to fit a sports cat in place of my cat bypass (too loud with my Fabspeed twin outlet), I'm assuming its just a case of bolt out and bolt in?
Thanks,
Chris
Old Feb 24, 2016 | 10:07 AM
rsabeebe's Avatar
rsabeebe
assuming you bought the right replacement sport cat...
Old Feb 24, 2016 | 11:58 AM
simonstorey's Avatar
simonstorey
Shameless plug: I have a virtually new Fabspeed sport cat for the 964 if you're interested. It has maybe 100miles on it. Looks brand new.
Old Feb 24, 2016 | 12:43 PM
ChrisG89's Avatar
ChrisG89
How do I ensure I do this? This is the one I was going to go for...
http://www.design911.co.uk/fu/prod12...l-Porsche-964/
Sorry Simon, but I'm in the UK! Thanks though
Will fitting the sports cat bring up any fault codes etc?
Old Feb 24, 2016 | 01:28 PM
rsabeebe's Avatar
rsabeebe
yes, that design will fit assuming you have all stock mounting locations - exhaust manifold crossover pipe and rear crossover pipe or equivalent. i always go with 200-cell cats and never get a CEL on any cars. others can speak for the 100-cells.
Old Feb 24, 2016 | 01:55 PM
ChrisG89's Avatar
ChrisG89
Why do you go for the 200 Cell?
Do you think the 100 Cell will be noticeable quieter than the cat bypass?
Thanks for your help, it's much appreciated!
Old Feb 24, 2016 | 01:57 PM
18T_BT's Avatar
18T_BT
No affiliation, but saw this in the classifieds: https://rennlist.com/forums/parts-ma...ffler-new.html
Old Feb 24, 2016 | 04:10 PM
tdiquattro's Avatar
tdiquattro
My 100 cell is loud, not much restriction there for sound or gases , I don't think it will be. Much different to a bypass. Where about are you in UK?
Old Feb 24, 2016 | 09:08 PM
Porschenut_Lee's Avatar
Porschenut_Lee
Chris,
Make sure you get a new square gasket and hardware for the inlet and it doesn't hurt to have a new donut gasket and clamp for the outlet just in case. Easy swap.
Old Feb 25, 2016 | 08:39 AM
ChrisG89's Avatar
ChrisG89
I'm near Chester in the North West.
I was thinking of replacing the Fabspeed twin outlet, but was hoping that the Sports Cat would be enough to quieten it down!
Old Feb 25, 2016 | 12:57 PM
DobermanDad's Avatar
DobermanDad
Yeah reading this, it was kinda a PITA to replace my cat. I put a bypass in, but it's the same project. Like Porschenut-Lee said, make sure you get a new gasket. Also I recommend having a buddy to help. Lining the muffler up with the cat was a lot more difficult than I thought. You'll have to loosen all your muffler straps to get some wiggle room. Good luck.
Old Feb 25, 2016 | 01:04 PM
Vandit's Avatar
Vandit
Remove the rear wheel and use a floorjack to support the cat as you get it into place.
Old Mar 3, 2016 | 12:25 PM
John@Fabspeed's Avatar
John@Fabspeed
Basic Sponsor
Hello Chris,
A Sport Cat will certainly take the overall exhaust note down a notch. You can also cap the passenger-side outlet on the muffler system and run it in a single-outlet configuration to take the exhaust note down as well, but the Sport Cat would be my go-to
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
