Revisiting an old thread...I plan on replacing my CD-2 with a CDR-220. I have the following questions:
The CD-2 has an Anti-Theft Wire. How do you remove the CD-2 without the alarm going off? Just unhook the battery?
I don't see a wire for the Anti-Theft on the CDR-220? Do you just leave that unconnected?
The CDR-220 has wires for Illumination and Speed (volume control). The CD-2 does not. Where can I look for these signals? I've heard the cruise wire for speed but not sure about Illumination?
Thanks and Happy New Year!!!
After doing some research, I found the answers to the first two questions. The CD-2 anti-theft circuit uses a switch that is normally open. When the radio is removed, the circuit closes to ground and enables the alarm. Unfortunately, the CDR-220 uses a signal that is normally closed so the anti-theft wire cannot be attached to the anti-theft "spade" on the CDR-220 chassis. Given this information, I disconnected the battery before removing the CD-2 and cabling.
Any insight into the Illumination and Speed (volume control) question.
I was not interested in one of these as I haven't heard great reviews. Although I was generously gifted one as an Xmas present and now I have no choice but to install it. I am removing a very nice Nakamichi CD400 which had a great sound to it but in all honesty I listen to my car stereo about 2% of the time. I prefer to listen to the car when I drive these.
The PCCM is made in China along with all the accessories. It is not like any other system I installed before. They give you connectors but no harness and the (typical) worst instructions you could imagine.
Someone clipped the factory harness on my car years ago so it has taken some time to do this correctly. I have some very nice wire from Porsche and Bell labs back from the 50's. My Father-in-law designed some of the intercontinental wiring and touch tone phone and I have spools of special wire that will not corrode and his claims were was the best material for audio signal. Didn't matter just made the job easier since i had it. All connections were soldered using leaded solder. I am a Shindo fan and Ken Shindo insisted leaded solder was better . I also have half my car apart so it made the install easier but it is a PITA to do correctly. I had some JL speakers for the fronts and JBL for the rears but I am more interested in the Apple carplay and nav than music. Don't tell my wife but I would never have purchased this as I don't like the PCM in my Macan which is basically the same.
I should be done today with the install just need to connect power harness. I will report back with how it sounds and functions. BTW these do not come with the map Micro SD card so that will need to be purchased separately if I chose to.
BTW I am assuming the green coaxial type factory wire is the alarm wire? I have one with nothing attached to it and my alarm works perfectly otherwise.
They offer a second mic for the hands free but it is big and ugly and not sure where to put it. I don't want it messing up my clean dash I just reconditioned.
I do like that I could fit the USB box into the ashtray. I never use mine and it hides away when not needed. It was a bit of work to get the wires fed as I had to drill and modify some parts.
Anthony, you're right, the green wire is the alarm. Normal circuit is open and will Alarm will trip if grounded. As for the other wires in your pic, Brown=Ground, Red/Black=Switch power, White=Antenna Booster, Red=Permanent Voltage.
Thanks. I was just curious how the green wire worked? So just by cutting it I am assuming it leaves an open circuit per the wiring diagrams. This is why my alarm is still functioning?
Maybe someone has an answer to this a well. After looking through the wiring diagrams and PET I see it was 93 and 94 they eliminated the crossover ( PET calls it a diplexer) and changed out the front woofer and tweeter. The earlier cars had either 1) a door speaker PN 91164543300 I am assuming RSA or something where no tweeter was supplied although I have yet to see a stock 964 coupe without the tweeter. 2) up to -92 Code M490 (vaguely norted as Sound System) woofer 91164541500 tweeter 91164541700 and diplexer 91164557500. or 3) 93- woofer 96464550300 and tweeter 96464550200 without DIplexer.
I always thought a diplexer was a coaxial splitter but I am assuming that it is what they call a crossover. My car is a 93 and had no diplexer but has both 964 woofer and tweeter part numbers. I swapped door cards to black from a 92 which has the diplexer. I don't have original speakers to compare so I am assuming they added some form of shunt or resistor to filter out low or high frequencies in the later 93 on cars eliminating the need for the crossover and that the M490 power amp was standard on the -93 cars? My car came stock with the CD-1 head unit. My amp and other components were removed before I purchased the car.
I finished the PCCM install yesterday and I have to admit it doesn't surprise me that it sounds poor compared to the Nakamichi it replaced. I am not all that concerned about the sound quality it is adequate for my needs and my exhaust will drown it out anyhow but would you eliminate the diplexer and just wire the speakers directly as they did in 93 on? I have 93 on tweeters someplace and that would allow the JL speaker to be a full range speaker vs just a woofer?
Correct, the alarm will trip if you "short" the green wire to ground. Note: Many other Porsche sound systems (eg. Becker) work the opposite. They connect the alarm wire to the chassis of the radio.
Porsche seems to be using Diplexer and Crossover synonymously. If you do a google search on 91164557500 you'll see something that looks like a crossover.
It's been a while since I replaced my M490 speakers with Infinity component speakers, so I don't remember what was in there. However, the wiring diagram in the service manual does show some sort of low pass filter before the tweeter. So, I would not wire the Porsche tweeters without one. That said, you'll may get better sound by just using the JL speakers in full range (assuming it has a tweeter).
