Chip soldered in
Was given a chip for my DME to try after some exhaust modifications. My chip is hard soldered into the board. Anyone out there ever removed one of these? I'm not about to muck it up for a minor gain. Thanks all.
Fred
Fred
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Fred,
You must be looking at the wrong chip. The 964 DME EPROM is mounted into an IC socket. It is not soldered. You have to open up the whole unit and pull the circuit boards apart to access the chip.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
Adrian is correct. I've never seen a 964 DME with a soldered in chip.
You're looking at the wrong board or you haven't removed the clip
which retains the chip to the socket.
Good Luck
Loren
Good Luck
Loren
