Motor oil
M1 5W-50 has a higher ZDDP level than very most other oils today.
https://mobiloil.com/~/media/amer/us...pecs-guide.pdf
If I were looking for a car, and finally found one that wasn't coming from an unscrupulous flipper that had thrown away all the meticulously held records from the previous owner, and the well meaning previous owner showed me he had changed the oil religiously with Mobil 1 the entire life of the car....id smile and start to have nightmares of cam lobe wear, and think to myself how much the top end rebuild is going to cost me...
What was once a very good synthetic oil, is no longer s good synthetic oil. Sorry to say. But our lovely government mandated out the zinc and phosphorus from our motor oil and from that point on, anyone using oil without zddp, was adding massive wear to all parts of the motor where two pieces of metal come together and particularly large flat areas meeting under pressure, like cams and tappets.
So...whatever oil you choose, the key is, don't believe the marketing, you can't get the type of oil from Porsche's 1992 "approved" list, because oil was different back then, and listen to the experts...buy oil with the right viscosity and the correct amount of zinc and phosphorus. Or your motor with eat itself...slowly...but it will...
Certain grades of Mobil 1 are indeed inferior to others. You couldn't pay me to run their 10W30 in any vehicle. With that said however their 0W40 is literally the most spec'ed oil in the world. If I were using the vehicle as a daily I would run M1 0W40 without hesitation. If I were mixing in some track use I would use their 5W50. Both are far superior to any mineral 20W50 on the market.
I usually don't answer back on posts like that. Only because we get into arguments easily it seems on threads...particularly about oil.
But in this case...
Keep in mind that the 0 10 20 and 30 40 50 etc are simply a measure of viscosity. Has nothing to do with quality or component makeup in the oil.
Has oil technology gone backwards? No. But, removing zinc and phosphorus, while ok for most components in a contemporary motor, was death to motors that were designed with any components where we had large flat metal surfaces under high heat and pressure, that needed lubrication between the parts. Ie, as an example, flat tappet cam motors. But this also extends to other parts as well...
Engine design changes made these components less necessary. Less necessary doesn't mean they aren't necessary. Most people keep their cars a few years and trade them in. Any oil on the market today will keep an engine running those few years. For me, I'd like my motor to go 20 years, 30 years, etc. 300k miles? If properly maintained, the bottom end of a 911 so go 200-300k miles and the top end should be right behind it with the exception of a valve job and guides...
If I were to use today's Mobil 1 0/40, this wouldn't be the case. But, after a fresh rebuild, using Mobil 1 would carry me a few years for sure.
With that. I'm ducking out of the oil discussion. I'll let Steve W or Colin or LN Engineering take it from here. My opinion is just my opinion. Use whatever oil you are comfortable with. There are plenty of places to send a motor out for rebuild.
But in this case...
I've been using Brad Penn but Jake Raby has had some bad things to say about it recently. Supposedly it was bought by another company and the formula changed.
If I can find Joe Gibbs locally thats what I'll be using. Otherwise I'll stick with BP
Just going to toss this out there...synthetic oils don't make cars leak. What happens is they don't thicken up as much when cold. The viscosity remains more constant from cold to hot...so when the car is cold and the metals shrink, tolerances aren't as tight and you will be more likely to see some dripping. Our cars are particularly notorious for cold dripping, (or pouring) particularly the early non head gasket cars. Nothing really to worry about....
I use it on an engine for endurance,
I send a sample to Blackstone, and compared to the previous sample that was Brad Penn, the Joe Gibbs showed much better.
Be careful with standard Mobil 1. I ran that for a long time and ignored the warnings in 2006 when the EPA forced the oil companies to change their recipes for engine oil. What I learned later is that the standard Mobil 1 has 800 ppm of ZDDP where as the V-twin has 1800. When I rebuilt my engine, I discovered galling on my cams. My machinist told me that was a result of using oil with low ZDDP.
Check this chart out...
Mobil 1 synthetic 15w50 has 1,300 ppm of zddp. I use this in my 964 living in Southern California. So far so good. It's cheap, available at every Walmart, and as far as I can tell, a good appropriate oil for our cars. I'll stick with this.
The oil tempest came about because most modern cars are designed to use modern fuel economy(low viscosity) and emissions friendly(low ZDDP) oils w/ low ZDDP. Thes oils are too light and have too little ZDDP for our cars and should not be used in them. As w/ OBD standards this is a problem that arose due to political meddling in the engineering process.
Note that only the so called fuel economy oils were severely affected, these oils all have the API Starburst symbol on them, the oils that are less or not affected have the older API Doughnut symbol. These fuel economy oils are used in new cars to boost Cafe milage requirements. Their secondary benefit is increased emissions control system life by being cat friendly.
Note the weight and ZDDP levels from when our cars were new in red below and the current spec for M1 in blue
historical ZDDP levels can be informative ie before the current ZDDP tempest
M1 API SH 15w-50 circa '93-96 1095ppm P, 1427ppm Zn
M1 API SN/SM current spec 1200ppm P, 1300ppm Zn
M1 V twin API SJ 20w-50 1600 ppm P, 1700PPM Zn great break in oil!!
Notice that the current spec M1 15w-50 is as good(actually better than) as the original when our cars were new 1993-1996 SH spec???
break in oil needs high ZDDP in the 1400ppm + range, but above ~2000ppm long term wear problems arise
I've tried to find the ZDDP levels for other oils but only Brad Penn 20w-50 w/ ~1500ppm Zinc and ~1340-1400ppm Phosphorus meets the specs and has published data
the 993 Cup used SH rated 5w-40 M1 or 5W-40 M1 Rally.
If you can find current oils w/ that wt. and w/ the '93-96 spec for ZDDP go for it.
I've also been hearing good things about Chevron Delo 15w-50 but have no experiance w/ it and don't really know much about it.
The LN site is worth poking around in for additional oil info info
