964 engine rebuild question
i mushed up my engine and the main crank requries three of the six connecting rod journals - machining. so i will machine them all to .50mm and require the oversized bearings. They come in .25 and .50 mm from factory oem...
so my plan is to get the 0.50mm oversized connecting rod bearings.
Looks like only available from porsche germany with 4 week wait time.
does anyone know who else may make em? mahle or otherwise.
the porsche bearings are expensive to boot.. $65 each pair x 6 from one of our fine sponsors on rennlist!!
plus my crank is bent and off by 10 thou.... that can be fixed also.
magna flux shows no cracks!
Merry Christmas...
Merry Christmas...
pedal cluster question, clutch pedal engages/disengages just an inch off the floor
my clutch was not fully disengaging and had to put the pedal to the floor with full body weight just to disengage.. bled the system, and the clutch has 70,000 kms on it (being a pro driver, that clutch cannot be fried, plus it looks pretty good as i have it out along with the engine and trans... )...
i brought into local specialist and he had figures it's the roll pin and bushings so i ordered new.
i removed yesterday and:
1. cannot figure how to remove the shaft that is connected to the clutch pedal... seems it should slip out but so far no luck - light taps with my 5 lb mallet?
2. when i inspect the roll pin and remove, it appears to be in fine shape. i expected the pin to be broken or damaged so... ?
3. there is lots of play and and an adjusting screw. the play is from the giant spring that sits below the brake pedal / accel pedal size and is very loose. does that mean it needs to be replaced or can i just adjust the screw until the play is gone?
4. anything to change while i have it in my hands?
5. could me issues be the master cylinder?
IHI KING!
https://rennlist.com/forums/964-foru...ake-pedal.html
RL Technical Advisor
Alex,
If you need .5mm undersize rod bearings, your only choice is factory and I'll warn you, they are not cheap.
.25mm ones from Porsche as well as Clevite 77 ones are available (very short supply) so if those will help, let me know ASAP as I have only one set left. More of them are several weeks out. These are reasonable at $350/set.
Steve, thanks for your input..
ugh... sounds like i'm going to need the .50mm as i can get away with five of the .25mm but cannot for the sixth which is 14 thou off and requires a 20 thou grind which means... .50mm.
i was told it would be best to grind the crank the same way all around to avoid confusion in future work on the crank shaft... which in my case may be next life?
i read somewhere that the glyco are not totally reliable?
would you mix up the grinds and con rod bearing sizes?
Is there a huge cost differential between the expensive .5mm undersize bearings + regrinding + straightening the old crank and replacing it with a new GT3 crank?
Just thinking out loud but if it was me I'd be looking at all the options available at this stage before jumping in.
mike,
just looking at my old posts.
had the crank repaired and machined to fit oversized / thicker connecting rod bearings which i ordered and came from Germany Porsche... took long time
had the shop property torque on and installed with new (to me) connecting rods - all matching
resealed motor and with fresh main crank bearings (regular size) and runs great, purrs like a kitten at idle and makes good power
broke in at the track after 300 kms of original oil change
put on about 3 or 4,000 kms since rebuild
