Well...could be worse.
Fortunately, soaking with PB blaster for a two days freed up a lot of the stuff, but not everything. One of those allen/barrel nuts started slipping on me, the VERY LAST ONE I needed to get loose. Everything else came off with some a little force and some of those scary creaks when something has been sitting for a long time. So I let this one barrel nut soak for another day, hit it with heat the next day, trying to be careful and not set the oil on the valve covers on fire.
But, it even starts rounding a bit more. Out of desperation and frustration I think about hammering on a 9mm allen and trying that, but halfway in I think of another set of tool in my fathers tool bag. They are these long allen wrenches with a t-bar like attachment, with all my strength it starts creaking loose bit by bit. BUT THE WHOLE STUD comes out with it. I prayed to all aircooled gods that it didn't snap, although it seems to be permanently seized to the nut.
The associating problem could be that the sockets I bought arent squared off but rounded at the top, with max grab being around the middle of the head, but only quarter of the ball fit in.
Moral of story...double check your tools, even when you think you have the right thing. Have a stud on order now, but got the other side fitted with the shiny goodness.
PS; I still can't split the two heat exchangers from each other for easier storage, after soaking and everything, it just seems to want to round the head of the bolt.
Some pics to go with the lackluster story.
EDIT: Looks like it's Sir Tools P243
A lesson I learned a long time ago especially when something has not been disassembled for a long time. I always give them a solid shot with a 2.5 pound or heavier hammer to make sure they are well seated before ever applying pressure. Similar to the seat bolt issue. Once it slips and gauls the nut you're done. Never liked the design myself that is why I keep two sets of those in stock. A lot of people swap them out with 12mm nuts. You can get a 12mm socket through there but not 13.
Glad you were able to get it off. You're not to far away if you run into trouble I have about every tool imaginable I am happy to help if I can.
