Distributor Question
My question is that no matter what I do, the rotor will not line up correctly. It is either before the notch or after the notch. In theory, should I be able to get it directly on the notch? I know timing is controlled by the DME so from reading other threads, may not be an issue. I just tend to like everything lined exactly.
Thanks.
Does anyone know how much rotor travel there is with moving the distributor one gear? It appears to be a little over 1/2 inch travel with each groove of the distributor gear. Based on what I have tried, I do not think I will get it to line up exactly like before. Hopefully it is close enough to not be an issue.
Should have everything back together to install during Christmas break.
nub, and then seat the distributor, it will rotate clockwise, slightly past the mark, which is O.K.
I am just not as confident at looking at the timing. I will verify TDC at least.
The dizzy runs off of the left cam. I absolutely would not run it if you see a chip on the cam gear. You said that you had the chipped gear repaired in the past? That would require replacing the left cam, something your wallet would certainly remember! However, that wouldn't effect being able to line up the rotors.
Do you remember how far off the rotor was from the pointer before you pulled it out to line it up? As much as 60 degrees? Possible that they used the wrong crank notch as tdc. Without a doubt, don't run it!
Couple points to make sure it is clear the situation (sorry so long):
* Engine just had top and bottom rebuild by a reputable shop. They are definitely not new to Porsche engines.
* Engine has not been installed yet (currently in the process of bolting everything back together)
* Distributor drive 930.102.112.00 (which looks like is on the crankshaft - not camshaft) was replaced as it had a nick. It appears new one now has one. Will call the shop tomorrow. The nick is not deep (probably not even a mm) so not sure how it would affect the distributor. Maybe someone has had this issue as well?
* Somewhat checked TDC - rotated engine to Z1 while observing a screwdriver stuck in cylinder 1. It definitely peaked close to Z1. I guess in theory it could be 360 degrees off, but the distributor rotors would have been way off if the shop was no where close on the distributor installation.
* I tried several spots when installing the distributor (took it out originally to see if I could line it up better). I tried before the mark and watched how much the rotor rotated during install. Backed it up to where it should have lined up perfectly, but distributor would not install. It appeared I was not a groove. So backed it up further to catch the next groove and the rotor rotated and stopped before the mark. I tried several times with no way getting it stop on the mark.
Questions:
* Since they installed a new distributor drive gear on the crankshaft, could it be slightly rotated and that is why the rotors will not line up on the marks?
* Does anybody know the rotation amount of one groove on the distributor gear? I am guessing there are about 12 grooves on the distributor gear, so each groove would in theory move the rotor 1/12 the way round the outer part of the distributor.
* So if the first question is that the drive on the crankshaft is slightly off, what can be done? I doubt they would tear down the engine again to adjust that only. Based on the below thread, the OP's car drove fine.
https://rennlist.com/forums/964-foru...one-tooth.html
* Has anyone seen a nick in their drive gear on the crankshaft? I am guessing it was done during distributor install. Trying to determine if it is really a large concern.
* Lastly, if I cannot get it to line up perfectly (per the shop, it does not need to), what is better - before the mark or after the mark? I am thinking before as the mechanical movement moves it to almost the mark. After the mark, the mechanical movement would move is very close to the next cylinder.
Again, thank you so much for all the input and sorry for the length of the post. It has been almost a year since I drove it last and really was hoping to have it back on the road by Christmas.
