Quick Wheel Help Please
It all depends on how your car is set up, I.e. How low and how much camber as well as the tire size. The fronts are about right, the rears would need 5-10 mm spacers.
1. Cup 1's
2. 996 10 Spoke Wheel
3. Fikse FM5 or FM10
4. ACT / Ronals
5. Sport Classics
http://www.ebay.com/itm/Porsche-964-...BWQQvG&vxp=mtr
OP is correct, these 18" wheels were optional on 986 Boxster S and have typical dimensions for Boxster 18" wheels [7.5 ET50 and 9 ET52]. They will fit your 964 as long as you don't run wider than 225/40-18 front tire because the front offset is slightly on the aggressive side, and you will probably want to space out slightly more in the rear for looks. As-is, they will fit fine though.
Good luck!
Good luck!
Good luck!
Good luck!
Don't confuse price with value. Why would you want to put "fugly" 18" Boxster wheels on a beautiful 964 coupe. So many other great choices out there.
1. Cup 1's
4. ACT / Ronals
5. Sport Classics
1. Cup 1's
4. ACT / Ronals
5. Sport Classics
The OP just asked if the wheel he wanted would fit....If you want to rock the Ronels then rock on with your choice and let the OP have his style
