FVD Brombacher - Shift into Winter Projects Sale - 20% Off - Ends Dec 21st
Let FVD Brombacher USA make your winter projects list a little easier on the budget. We are offering a 20% discount on clutch kits, clutch forks, clutch hoses, transmission mounts and a short shift kit.
The sale will start now and will end the first day of winter, December 21st. To take advantage of this sale, simply click the link for the part or parts below and order on the online shop.
Enter the Promo Code: Rhonda 1 to get the 20% off.
Clutch Kit - SACHS SPORT - For Light Weight Flywheel (370 ft/lbs. max.) – FVD Part # FVD 116 102 1
$ 956 Your Cost!
Clutch Kit - SACHS SPORT - For Dual Mass (OEM) Flywheel (370 ft/lbs. max.) - FVD Part # FVD 116 102
$ 956 Your Cost!
FVD Exclusive Clutch Kit - For Light Weight Flywheel (370 ft/lbs. max.) - FVD Part # FVD 116 102 2
$ 1,199 Your Cost!
FVD Exclusive Clutch Kit - With Light Weight Flywheel (370 ft/lbs. max.) - FVD Part # FVD 116 905 1
$ 1,524 Your Cost!
FVD Exclusive Clutch Kit - With Light Weight Flywheel (315 ft/lbs. max.) – FVD Part # FVD 116 905
$ 1,624 Your Cost!
FVD Exclusive Clutch Kit - With Light Weight Flywheel (350 ft/lbs. max.) – FVD Part # FVD 116 905 2
$ 1,749 Your Cost!
Clutch Release Fork and Shaft Kit for G50 Transmissions – FVD Part # FVD 116 999
$ 236 Your Cost!
Stainless Clutch Hose – FVD Part # FVD 423 477 00
$ 41 Your Cost!
Transmission Mount - SPORT - 85 Shore – FVD Part # 964 375 055 80
$ 107 Your Cost!
Transmission Mount - SPORT - 85 Shore – FVD Part # FVD 375 003 S
$ 74 Your Cost!
Short Shift Kit – FVD Part # FVD SK5
$ 180 Your Cost!
FVD Brombacher Inc. serves North and South American Customers. The Your Cost prices listed above are estimated, the online shop will calculate them to the penny for you. Shipping is not included in the Your Cost above mentioned pricing. Please allow the online shop to calculate that for you.
Did you know?
Quality means everything to us, so we only source these parts directly in Germany. That may not mean a lot to some, many think that all of these parts come from Germany anyway. Not always the case!
Many OEM equipment manufacturers produce parts outside of Germany and even outside of Europe. Simply put, Quality Control Standards for those parts are not as high.
The reason that there are higher standards for Germany is due to an Automobile Repair Regulatory Agency called Zentralverband des Kraftfahrzeughandwerks, ZVK for short, which translates to Central Association of the Automobile Repair. All parts and repairs made inside Germany carry a “warranty period” of 2 years according to (§ 634a para. 1 No. 1 BGB, http://www.kfzgewerbe.de ). That means that parts supplied inside Germany are typically of a higher quality and tend to come from manufacturers in Germany and Europe.
The parts that we sell don’t have these out of box failures that are becoming so common in the U.S. That is why we insist on the added expense of air freighting our parts in from Germany. We may be judged as the “high water” mark in the industry but we will not change our stance, and rest assured the parts you buy from us are of the highest quality.
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Want to learn more about us? Click here...
Rhonda Roxburgh
+1-954-571-2050 x 1
