964 Forum 1989-1994
Engine mounts
Old Nov 9, 2015 | 03:40 PM
Saab96's Avatar
Saab96
Thumbs up Engine mounts
Is this engine mounts good to go?
Old Nov 9, 2015 | 03:54 PM
crg53's Avatar
crg53
Hard to tell. I would install it and see how far it hangs down after you add the weight of the engine.
Old Nov 9, 2015 | 04:21 PM
Saab96's Avatar
Saab96
Left mount
Old Nov 9, 2015 | 04:29 PM
crg53's Avatar
crg53
Yes, they are ready for replacement. When I replaced mine, I bought the 993 C4 mounts, much cheaper than 964, and they have worked very well for me.
Old Nov 9, 2015 | 04:53 PM
911Jetta's Avatar
911Jetta
Welcome to Rennlist Saab96.
Replacing worn motor mounts will improve your car's handling (and sometimes the shifting).
Here's a link to my motor mount experience; I chose to install Wevo motor mounts (no affiliation) but there are a couple good options.
Wevo m.m. installed - impressions
https://rennlist.com/forums/964-foru...pressions.html
Old Nov 9, 2015 | 04:54 PM
Goughary's Avatar
Goughary
Buy wevo mounts w black cushions. You will love them.
Old Nov 9, 2015 | 06:17 PM
peter_jansen's Avatar
peter_jansen
+1 and consider reinforcing the carrier.
Old Nov 9, 2015 | 11:19 PM
Goughary's Avatar
Goughary
Yeah. I've just seen three sets of rear oem stock carriers terribly bent. Definitely a good idea to call rennline, buy their reinforced mount, and then send yours back to them for the rebate. It ends up not costing much and makes a big difference...since it won't bend...
Old Nov 10, 2015 | 12:35 PM
montys964's Avatar
montys964
I have to replace mine. Looks pretty straight forward but never done it before so I would like to see done first. Any videos out there the community can point me to? I tried Google/YouTube with no luck.
Old Nov 10, 2015 | 02:32 PM
DobermanDad's Avatar
DobermanDad
It's pretty easy. Support the engine with a jack. Replace each mount one at a time. You'll need the jack to adjust the height of the engine once a mount is removed to reinstall it.
I really was surprised how easy it was. I planned at least a few hours and it took me about 15 minutes.
You'll need a torque wrench to keep everything in spec. and a extension for the socket that removes the large lower nut. Both of mine came right off, you can always hit them with a little PB blaster a few days before the job if you're worried about them coming off.
Old Nov 10, 2015 | 03:27 PM
dhc905's Avatar
dhc905
I have a set of Wevo's available with both the blue and black pillows if anyone doing this is interested. Ultimately decided to just use my RS mounts for this...
Old Nov 10, 2015 | 03:47 PM
DTMLGND's Avatar
DTMLGND
Interested. Pm'd
