Looking for advice on rotors...
I need some rear rotors for my C2 coupe. I would like to get slotted or regular flat face rotors if that's recommended. There seem to be a lot of options on Pelican and other sites so I wanted to see what others have used with good results. I definitely want something that has a coated center so it doesn't rust.
I didn't see any but to confirm there aren't any 2 piece options until you upgrade to the 993tt big red calipers. Also, the car might get a few track days so I wasn't sure if a cryo rotor would be worth the investment.
Thanks,
Mike
Thanks,
Mike
I bought the solid sebro rotors at pelican. They were inexpensive and have been great. No issues at all. You don't need the added cooling of slotted rotors unless you are doing long track sessions of 30 mins plus....so go slotted for the look if you like it, but don't be concerned about slapping a pair of sebro on the car and being done...
Originally Posted by MTR
Inexpensive rotors sound good to me. Are the centers coated so they don't rust?
Here are some options for your application. Please let me know if you have any questions or if i can be of any further assistance.
https://www.carpartsdiscount.com/cat...html?3594=2111
http://thmotorsports.com/i-328911.as...gHUaAqkT8P8HAQ
No affiliation but I ordered my rotors from them and really like the slotted look. $80 aint bad either
Thanks Vancleef. This is the route I'm going to go. I haven't decided wether it's worth the extra ~$20 per rotor to get the cryo treatment. Also I hear you can't turn slotted rotors, so that's a downside. But they look great and stoptech is a legitimate brand. Post some pictures when you get yours installed.
Mike
Mike
I will be going the route of slotted (as I run on my 996t) as I go through a set of drilled every year or two with the track outings I do (cracks radiate from most of the drill holes)!
Having said that, you've also got to take into consideration pad surface area, brake fluid boiling point, condition of hoses, pad material, etc, etc
Our cars are awesome on the brakes as standard....for the road and occasional track work.....to properly threshhold brake them requires plenty of practice (and a little tuition)
