964 Forum 1989-1994
1990 C4 Starting Issue
Old Sep 17, 2015 | 12:40 AM
jwdwight's Avatar
jwdwight
Default 1990 C4 Starting Issue
I just bought a 1990 C4 back from my father who I sold it to in 2004. The car has been driven very little in the past few years and has 61,000 miles. The other day the engine started to cut out as I pulled up to a stop sign. It did die and I was able to start it. This morning I went to start the car and it would not start. It turned over but absolutely nothing. I pushed the car out of the garage to see if I could start it by popping the clutch in 2nd gear. Finally after about the 6th try (it's a long hill), it started. Drove it back to my garage and shut it off. It started when I tried again. Any ideas what is going on or where I should start the trouble shooting?
Old Sep 17, 2015 | 01:03 AM
jeanhules's Avatar
jeanhules
Did you get the battery tested to see if you need a new one? I recently had a similar issue. Ran a few tests on my own, but ultimately went out and bought a new battery and all was good (most battery stores will run a battery test for free). My fear was a bad alternator. A test I came across which tells you if you need a new alternator is to unplug the positive terminal on the battery while the car is running --- If the car immediately turns off, you have a bad alternator, otherwise it's something else.
Old Sep 17, 2015 | 01:09 AM
jwdwight's Avatar
jwdwight
jeanhules, thanks for you reply. I probably wasn't clear. The battery isn't dead. It cranks just fine. Just won't start. Doesn't sound like there is any spark at all. Maybe fuel filter? Strange that I did get it started by roll starting it but it took six times.
Old Sep 17, 2015 | 10:12 AM
fasterlaster's Avatar
fasterlaster
I'd say there is a real good chance it's the DME relay. Replace the current relay with a known good or new.
Old Sep 17, 2015 | 10:35 AM
jwdwight's Avatar
jwdwight
Thank you!
Old Sep 17, 2015 | 10:38 AM
bmohr's Avatar
bmohr
just a thought to check if you have fuel pressure at the rails. I had a similar stalling episode that turned into a no crank issue. Turned out I had a split in the fuel line that runs from the back of the fuel filter all the way to the front of the car.
Old Sep 17, 2015 | 11:12 AM
jwdwight's Avatar
jwdwight
Thanks bmohr! Will take a look
Old Oct 8, 2015 | 12:12 PM
jwdwight's Avatar
jwdwight
FasterLaster - replaced the DME relay with one I ordered from Pelican Parts. Plugged it in and started up immediately! Thanks for the help.
Old Oct 8, 2015 | 12:13 PM
jwdwight's Avatar
jwdwight
Replaced DME relay and started right up! Thanks for the help
